07-23-2002, 12:40 AM
CF Senior Member
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11
Location: Frankenstein never scared me. Marsupials do, because their fassst…and they DART, THAT'S crazy!
Re: Wiring early C4? (JOHNL)
First of all, what size amp are you going to use? I would prefer to use 4-guage power and ground wire just in case you decide to upgrade in the future. You don’t want to have to rewire the car if you do. The best way to run power from battery to back of car is to drill just above and to the right of the gas pedal or above and to the right of the break pedal. This will put you in the engine compartment just below and to the left of the power break booster. There is nothing there to get in the way and is an easy run from there to the battery.
Don’t waste money and wire trying to ground back to the battery. Ground at any of the rear bolts that bolt the seats to the floor pan. It is a solid 12v ground to the frame and very easy to get to.
Yes, you should run all new speaker wire. Just leave the Blose wiring where it is and don’t mess with it, you may need it someday if you decide to sell the car and put the stock system back in it. Run the speaker wire under the hush panel, under the carpet between the seat and the doorsill, up behind the seat, over the fender well and into the opening for the speaker. You will have to remove some trim and pull up the carpet but it is really quite easy.
Don’t forget to fuse the power wire within 18” of the battery.
Good luck. :seeya
