Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-21-2002, 05:02 AM   #1
MY2K2C5
CF Senior Member
MY2K2C5's Avatar
Send a message via ICQ to MY2K2C5
Default HU power question
I know that this may sound stupid but I am curious just the same. I have my entire system wired in and all of the carpet back in place as well as the trim. I still have the center console to finish and I am glad I didn't put it back yet.
I am wondering as this is odd to me. I have the HU connected to the appropriate wires... how much voltage should I be getting with a check at the yellow wire/accessory? I get about 10VDC. I first had the HU connected to the OEM harness but had no power to the HU. I then connected to the wires in the floor panel. Still the HU does not power up. I have the voltage and a good ground.
Shouldn't the HU power up with all necessary wires connected...??? I thought that was the general idea of the whole thing :cry
I tried it for about 4 hours with every conceivable idea I had. This HU has 5 built in options for security and such that I am not connecting. Could this keep it from powering up? I doubt it. It won't even suck in a CD...
What do you guys think.. I think that the HU is forked... Going to buy a new one tomorrow..hope that I can find a stereo shop open on Sunday.
Last question and I am outta here... looks like I have to get a DIN stereo this go around.. what is the appropriate adapter I need. I have looked and am unsure.. I would like to finish this whole project up without anymore unpleasantries...
Thanks everybody...
MY2K2C5 is offline   Reply With Quote
Old 07-21-2002, 12:18 PM   #2
99HT
CF Senior Member
Default Re: HU power question (MY2K2C5)
How do you know that you wired the new HU into the car properly? Did you have a schematic of the Bose system or a listing of the color codes for the stereo harness?
Use this info to check your wiring. DO NOT connect to any other wires in the harness.
Signal CD/Radio connection
Power C1(10) ORG
ground C1(5) BLK/WHT
RF+ C1(4) DK GRN
RF- C1(3) LT GRN
LF+ C1(2) TAN
LF- C1(1) GRY
RR+ C2(18) DK BLU
RR- C2(17) LT BLU
LR+ C2(20) BRN
LR- C2(19) YEL
[Modified by 99HT, 10:24 AM 7/21/2002]
99HT is offline   Reply With Quote
Old 07-21-2002, 01:37 PM   #3
MY2K2C5
CF Senior Member
MY2K2C5's Avatar
Default Re: HU power question (99HT)
I followed this link and then wired accordingly.
http://www.corvetteradios.com./Page3.html
I have already replaced the stock speakers w/CDT Audio speakers in the doors and rear.
I hooked the positive and negative like you said and still nothing... :confused:
What do you think?
Old 07-21-2002, 03:04 PM   #4
JoeyG
CF Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
JoeyG's Avatar
Which wire are you measuring 1 volts on? From the passenger floor pan wiring, or from the factory radio wire harness?
JoeyG is offline   Reply With Quote
Old 07-21-2002, 06:26 PM   #5
MY2K2C5
CF Senior Member
MY2K2C5's Avatar
Default Re: HU power question (JoeyG)
From the factory wiring harness at the back of the HU...
Old 07-22-2002, 10:47 AM   #6
JoeyG
CF Senior Member
JoeyG's Avatar
Measure the voltage at the passenger footwell, where youhave your Valentine wired to. There are three wires, 12+constant, 12+switched and chassis ground. Measure the 12+ constant in the floor panel, which sould correspond to the yellow wire harness wire, if the is 12+ or more use the floor lead. If not theres something dragging down the 12+ constant supply on that circuit.
Old 07-22-2002, 10:58 AM   #7
92TripleBlack
CF Senior Member
92TripleBlack's Avatar
Is the car running when you test the wire? Could be just lower because its off.
92TripleBlack is offline   Reply With Quote
Old 07-22-2002, 12:15 PM   #8
JoeyG
CF Senior Member
JoeyG's Avatar
Default Re: HU power question (92TripleBlack)
10 Volts?
Old 07-22-2002, 12:33 PM   #9
MY2K2C5
CF Senior Member
MY2K2C5's Avatar
Thanks all for the replies and here is a synopsis of what I did.
I had the Pioneer HU and on Saturday I started wiring it in since I had all of the wires ran and was ready for this step of the installation. I went to Car Toys and bought an antenna adapter and also a wiring harness adapter. I first hooked up the wires according to the HU instructions and the color coding from the website listed above.
Nada...no power at all... I then broke out the trusted Fluke DMM and started checking the circuit. I had 12+ VDC at the wire in the harness @ the stereo. I had a good ground at the harness. Only about 1 volt at the accessory wire at the harness. I was like, damn must be some sort of step down in the circuit. Then wired into the wiring in the floorboard.
Nada...nothing again. I was wondering what in the hell was going on.. Doing the DC part of the entire project was going to be the easiest part of the whole thing. That was not to be. I then went to the battery and hooked a wire to + and then to a ground and still nothing. I was really pissed then. Was about 1230 in the morning and was tired and pissed.
Posted on here with this thread and went to bed. Awoke and went to Car Toys. Purchased a new JVC do everything HU. Also an adapter for DIN. The DIN adapter was perfect install. :D Next came the HU. It went in like a glove. Connected all of the wires using the harness. Nada... didn't work. I was getting pissed again... Went to the floorboard and hooked it up...
Bada Bing... That was the ticket... I then cleaned up the wires behind the HU and finished off the install. It looks great and the car is all back together.
Total time on entire stereo upgrade.. about 2 weeks off and on.. Tonight I will put the AMP rack in and wire it up and should be the end of that.
Moral of the story is.... If your wife ever wins a door prize from the US Government Christmas Party...throw the damn thing away and do not give it a second thought... threw the Pioneer HU in the circular file cabinet last night and slept like a baby...hehe... :jester
Thanks all...
[Modified by MY2K2C5, 7:35 AM 7/22/2002]
Old 07-22-2002, 04:35 PM   #10
JoeyG
CF Senior Member
JoeyG's Avatar
That kinda sucks, glad everything is working. :cheers:
Old 07-22-2002, 04:43 PM   #11
MY2K2C5
CF Senior Member
MY2K2C5's Avatar
Yeah.. it really sucked and better than a Bangkok Ho!... :D
I am still finishing my Amp box but I have very high hopes that that will go off without a hitch. The only thing is, that after looking at others posts my setup will be a little off since I have one silver amp and one black amp. Hmmmm...can't afford another McIntosh amp at the moment. :eek:
Do many peeps have different colored amps in their rides?
Everyone seems so uniform...hmmmm... :p:
Old 07-22-2002, 06:02 PM   #12
JoeyG
CF Senior Member
JoeyG's Avatar
Diversity is a spice of life :smash:
Reload this Page HU power question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
CDT 6 Install Question FYNL4 Audio/Electronics 14 11-15-2003 12:03 AM
question for ZO6 folks! syf0n C5 Z06 Discussion 31 09-30-2003 01:58 PM
Question about C5 Stereo Install AP Audio/Electronics 13 10-26-2002 01:39 AM
Installation Question Craig Brumley Audio/Electronics 16 10-01-2002 09:50 PM
Subwoofer question DngrZne Audio/Electronics 12 01-07-2002 01:31 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
