Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Closed Thread
Old 07-21-2002, 03:09 AM   #1
DETROITc4
CF Senior Member
Send a message via AIM to DETROITc4
Default Installing 1 10" Type R in storage bin, tips anyone????
im goin in to buy a 10" Alpine Type R tomorow and a V12 amp and am gonna install in storage bin, or at least try, are there any tips or things to look out for?i already have power and remote and RCA's ran, as for the storage bin, any cutting required, dynamat, stuff like that
thanks
DETROITc4 is offline
Old 07-21-2002, 07:24 PM   #2
buddha
CF Senior Member
buddha's Avatar
Default Re: Installing 1 10" Type R in storage bin, tips anyone???? (DETROITc4)
You really should have a fiberglass enclosure made for it in the exact volume specified for that sub. Sealed or ported depending on what it's designed to work best in. Any good car audio shop should make you one for not too much money, you should get a good deal from the shop you're buying the sub and amp from. Might have to shop around a little.
buddha is offline
Old 07-21-2002, 08:05 PM   #3
AP
CF Senior Member
2008 Chevrolet Corvette
AP's Avatar
Default Re: Installing 1 10" Type R in storage bin, tips anyone???? (buddha)
You could try to make your own sub box ... its not that hard ... I suggest that you make it out of 3/4inch MDF for the C5 ... mrkln has plan's on the web ... the MDF is stronger.
While fiberglass will fit perfectly ... it has a chance to crack under pressure ... My friend created a pure 'glass box and it cracked ... a MDF/Glass mix, ie ... MDF substructure ... Glass lid ...
AP is offline
Old 07-21-2002, 09:14 PM   #4
DETROITc4
CF Senior Member
Default Re: Installing 1 10" Type R in storage bin, tips anyone???? (NewVetteLover)
his plans would work if i had a c5 :yesnod: but im installing it in my 86 c4, i have made custom boxes before but i was thinking if i sealed it off real tight and maybe layed some dynamat that it might just work,
Old 07-21-2002, 09:18 PM   #5
AP
CF Senior Member
AP's Avatar
Sorry ... I didnt notice your tag ...
AP is offline
Old 07-21-2002, 09:39 PM   #6
DETROITc4
CF Senior Member
its cool. but thanks for the tip for the c5 my dad wants a lil more bass in his 97 maybe ill have to whip up a box for his vette
Old 07-23-2002, 02:42 PM   #7
gcrouse
CF Senior Member
gcrouse's Avatar
That's exactly what I did with my 10" JL Audio sub and it sounds great; assuming you're not trying to set SPL records. My storage lid replacement is 1/2" MDF running all the way across, glued/screwed to 3/4" MDF that fits just inside the right compartment; so that baffle is thick. The walls are still fibreglas with two layers of dynamat-like dampening sheets. Even if they flex some, it's outside the listening environment anyway (underneath the car). Without doing the full box, you could also epoxy some 1/4" plywood pieces to reinforce the walls if you wanted.
gcrouse is offline
Old 07-23-2002, 06:14 PM   #8
kenfusion
CF Senior Member
kenfusion's Avatar
Send a message via AIM to kenfusion
DetroitC4,
got your IM, I'll send you over the results from our attempts at the same project later this week. So far we have made one removable box that sounds pretty good. I am also going to try make a slide in lid design that will seal the enclosure utilizing the space itself as a box. I imagine that this will require quite a bit of dampening and some structural work to avoid warp and harsh resonance etc. Ideally If we are pleased with the results I'll have the specs drafted up in cad and post for others to use.
Ken :cheers:
thanks
kenfusion is offline
Old 07-24-2002, 03:32 AM   #9
DETROITc4
CF Senior Member
Default Re: Installing 1 10" Type R in storage bin, tips anyone???? (kenfusion)
thanks kenfusion i got my Type R today it looks like its gonna be pretty good, the magnet on this thing is unbelievable, i just gotta get it all setup tomorow i got a roadtrip and i leave on thursday so i got a day to work on it, what did you make the box out of, mdf?
im gonna im you so if your on give me a holla
thanks
ryan
Old 07-24-2002, 02:50 PM   #10
Sexy99C5
Junior Member
Sexy99C5's Avatar
I got 1 Alpine Type R 10" in the back of my C5, and man does that thing sounds nic, good luck with it. I made my box out of mdf....
Sexy99C5 is offline
Old 07-26-2002, 01:06 AM   #11
NUckINg FuTS
CF Senior Member
NUckINg FuTS's Avatar
Default Re: Installing 1 10" Type R in storage bin, tips anyone???? (Sexy99C5)
I went the same route as gsrouse. All I did was cut a 32in by 14in board out of 1/2in MDF and reused the existind screw holes. Then I lined the storage compartment with Dynamat sound dampning material and filled it with polyfill. Oh ya, I also used rubber weatherstripping to seal the board to the fiberglass. I am using an Infinity 10" sub with a sony 760w amp and it sounds better then many bigger systems I have heard. Install pics to come very soon.
NUckINg FuTS is offline
Old 07-26-2002, 02:22 AM   #12
DETROITc4
CF Senior Member
Default Re: Installing 1 10" Type R in storage bin, tips anyone???? (NUckINg FuTS)
yeah that sounds like what im gonna do after all, i tried to make a box type thingy for the bin but just such a weired space i might just do the 32 x14 mdf like you said and just make sure its sealed down nice and tight and maybe use some dynamat
would like to see pics or your install nucking futs
Old 07-27-2002, 10:09 PM   #13
NUckINg FuTS
CF Senior Member
I'll try to get pics up as soon as possible.
Old 07-31-2002, 02:58 AM   #14
DETROITc4
CF Senior Member
i finished up my install tonight and havent had time to post pics as of now i have the one 10" type R and one peice of crap 300 watt no name amp i borrowed from my friend until mine is off backorder, but its sealed down in the passenger side storage bin and i think as of now even underpowered it sounds better than my 2 12" mtx's i had in there before pics forthcomin late evening tomorow
Reload this Page Installing 1 10" Type R in storage bin, tips anyone????
Closed Thread
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
