Double DIN to single DIN + mini storage compartment?
This might sound like a stupid question, but I've had the idea for a long time. Has anyone ever take a factory double DIN and put a single DIN stereo with a custom cubby hole underneath for CDs and stuff? Is this even possible due to the limited space?
Re: Double DIN to single DIN + mini storage compartment? (FroDaddy)
I just did it in a C4. Used a Metra dash pocket kit. Tight fit but it turned out pretty nice.
Re: Double DIN to single DIN + mini storage compartment? (Bradley3)
I looked on their website for C4 corvette and a C5 corvette, but didn't find the pocket kit. Do you have to use a universal GM one? I'm planning on putting it in a C5.
[Modified by FroDaddy, 9:28 AM 7/18/2002]
The C5 is a din and a half, not a double din. It needs a different kit. For the C4 '91+ I used the din pocket from Metra.
Re: Double DIN to single DIN + mini storage compartment? (92TripleBlack)
I found the C4 kit on their site (finally), but didn't see one for a C5. Is this because a DIN and a half would be too small to put a pocket underneath?
Din and a half is to small for a pocket. The best looking kit to me is the one that mounts the radio in the middle with half of the space above and half below. Works out to about 1/4" of plastic on each spot. The other option is with a half din blank below. This is nice for mounting alarm LEDs, gauges, switches, or emblems. Hope this helps.
Actually, I e-mailed them and here is what they said:
Their website is http://www.Metraonline.com
Then I e-mailed them since the part # is not specifically for a C5 vette, and here is what he said:
:cheers:
THE KIT FOR A SINGLE DIN RADIO AND A POCKET IS A 99-4000 FOR A 97-2002 CORVETTE.
THIS KIT FITS SEVERAL DIFFERENT GMS.THEY USE THE SAME RADIOS IN SEVERAL DIFFERENT MODELS OF THERE VEHICLES.THIS IS ONE OF MY FAVORITES TO USE WHEN I CAN.THIS KIT WILL LOOK THE BEST.
Re: Double DIN to single DIN + mini storage compartment? (Big_John)
Does anyone have a part number for a 91 c-4 metra kit? I've looked and looked at the Metra web site and tried emailing them a couple times with no luck. Is this a universal kit? Or is it specific to the late c-4. Or do I just need to fabricate something?
Try e-mailing Tom Reece, he's the one that helped me out:
Tom Reece
tomr@metra-autosound.com http://WWW.Metraonline.com
1-800-221.0932 ext. 314
Tom Reece
I also would like to install a single din/pocket to replace my double din (93 C-4). What did you find out? I've been unable to find someone local who I trust to do it (Arlington, Texas). Drop me a line. Keith :nonod:
Re: Double DIN to single DIN + mini storage compartment? (kmath)
Thanks. Keep me posted. Are you doing the install yourself? Good luck.
