Help with OEM-1 and amp/sub
Location: Fredrikstad, Norway - sorry if my english isnt to good...
1 Post
Hi!
I am installing the oem-1 unit and an amp and sub to my stock HU. I cant get the amp to turn on.. I have the remote from the amp to the blue wire on the oem-1, and the green wire from the oem-1 to the pin nr. 8 (dark green) on the black factory plug, is this the wrong wire? Its a 99 coupe. Anybody have any thoughts?
Thanks,
Frank
Thanks,
Frank
1 Post
Hi!
Thanks! The green wire on the OEM-1 is labeled "connect to pin nr. 8 on the black factory connector".. I tried to connect the amp remote wire directly to the pin nr. 3 on the factory connector, and this worked! I found info on the nr. 3 pin on the forum. So i can use this setup without doing any damage to the system?
Frank
Frank
1 Post
Ok, i found out what i was doing wrong.. I was counting the pins in the connector from the wrong side.. The pin nr. 8 from the wrong side is also a green one! I am a little embarassed Now, everything works like a charm
Frank
Frank
