Issues with invisicord for valentine one c6
I plugged the cord into the back of the mirror as the directions show and before plugging the harness back into the mirror I decided to test the unit but I am getting no juice when the car is started. Is there a trick here I am missing. Seemed like a straight forward install but I seemed to have goofed it up
It sounds like you need to choose different connections meaning one that is powered when the car is on. I can check mine tomorrow for the specific ones I used.
Do you have the pins fully inserted?
Sometimes this requires trying different sides of the socket before the pin will push all the way in.
Use the cable ties to keep them firmly in place.
Plug it back into the mirror and if it still doesn't work, check the fuse.
