Wiring Help Needed
Wiring Help Needed
I have a 96 coupe with the Bose Gold system in it. I bought a Pioneer AVH-X8500BHS head unit and the Metra 70-1857 kit. The two questions I have are the Metra kit does not have a wire for illumination going to the Pioneer. There is an orange wire at the factory plug that plugs into the Metra kit. Where can I tie into the factory wiring to get this? I'm afraid the Pioneer will be too bright at night unless it dims down when I turn the lights on. I am also running a ground wire directly from the battery to the ground at the head unit. Would it be okay to also run a hot from the battery to the constant 12 volt at the head unit and Metra constant 12 volt? The battery hot will have an inline fuse.
Thanks,
T
Thanks,
T
Well after all the views and no answers I will have to assume that they were very dumb questions or nobody knows the answers. I guess I'm on my own to figure it out.
T
T
