After almost 2 years of bit/piece...crazy install
**NOT RED anymore**After almost 2 years of bit/piece...crazy install
Hello All,
Thought I would share a few pics of finished install. I started with a package deal from DD Mods (which is still installed). Read a lot of DIY's on this forum, picked up a few more amps, researched building a fiberglass sub box (got ideas for shape/dimensions off this forum). Built it and an amp rack. First time taking on a project like this.
The box and amp still allow targa storage...the small "pod" mounted on the sub box holds 6.5" components and the tweets are installed in the halo. I hand laid the pod with left over sub box materials.
I know...box is definitely "RED". Best thing is is if I get bored with it, can repaint it quite easily. I like it though...
Total system is 2 10" sundown SA10 subs, Polk components, Helix components, Pioneer amp, and 2 Orion Cobalt amps. Yeah...overkill but sounds terrific. I wanted a fast stereo and I got one
Last edited by Slomo051; 04-19-2014 at 10:44 PM. Reason: Changed build from red paint
Changed from red sub box to two tone carbon/color match
As I said in the original post if the red color got old I would change it...I did...I ended up two-toning the box (used supersonic blue paint) as new photo shows. I "skinned" the front in carbon fiber and the pod attached to the sub box. I liked the red...I like this setup better. Ton of work and patience when working with carbon fiber...
Received 4,505 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Like it, only problem I can see is that you can't hear the wife talking would love that, and if you travel for getaway weekend, no space for luggage, other then that I want it.
Thanks!! I drive out of town often for a few days for the job. I can still hold a carry on style bag quite nicely in the back...of course either top or bag. Choices...
