Sponsored by: DashLynx
factory XM only with aftermarket radio
Old 06-17-2013, 08:35 PM
impact1968
impact1968's Avatar
Default factory XM only with aftermarket radio
2007 C6 coupe
I've removed the stock nav radio and bose (blose) amp, because I have an aftermarket radio I want to install. I ran power from the battery for the radio, and ground to the chassis (it's nice not having chimes).
I left all the factory wiring in place and would like to know if I can connect my radio to the factory XM receiver? The radio is XM ready, it has a cable jack in the back.
Is there a cable that goes between my radio and the XM receiver?
Old 06-17-2013, 08:50 PM
markcz
markcz's Avatar
Can't be done.
You can use the oem antenna with an aftermarket sat receiver if you pull apart the plug, but that's it.
Old 06-18-2013, 06:32 AM
impact1968
impact1968's Avatar
Thanks for the help, my life just got easier.
To factory XM only with aftermarket radio
Quick Reply: factory XM only with aftermarket radio
