Maybe you could have the amps “Flush mounted”. That would help solve the heat problem and look cool. Cut holes in the top and have just the top of the amps exposed flush with the top. Also, put a couple CPU fans in there. One in the back blowing forward and one up front behind the driver seat blowing forward to a vent in the side. Between the two you should be ok with heat dispersal.
I would also carpet that top; it will look more stock that way and give the illusion that your amps are sunk into the floor.
Here is my amp rack by itself. It flows into the sub enclosure when installed but you can see that the amps and cap are flush mounted.
When installed it all looks sunk into the floor. I finnished my electronic crossover cover and will take a pic of the finnished look and post it. Maybe you'll get a better idea what I mean when I do.
Your systems looking good. What is in that gray enclosure Kale, a 10" sub?
