06-21-2002, 12:48 AM
CF Senior Member
Re: Mixing sub sizes - bad idea? (webdzynes)
Depends how you cross them over. You want them to produce mid bass taking that task away from the main sub, and you want them to be level adjusted to make it a seamless transition of sound. The last thing you want is them both fighting each other over the same frequency range. maybe the 12 does 40 down and the 8s 40-100hz or so. You'd have to play with it. I'd get a really good shop with a spectrum analyzer to do it unless you have the equipment to max it out. Otherwise, the pair of 10s will be much easier and yield almost as good if not equal results.
