Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-20-2002, 11:44 PM   #1
whip383
CF Senior Member
whip383's Avatar
Send a message via AIM to whip383
Default How do I tap the wire so my XM stays on without the ignition being on?
Anybody, maybe color of wire, location, i think near passenger footwell??
Chan
whip383 is offline   Reply With Quote
Old 06-21-2002, 02:28 AM   #2
whip383
CF Senior Member
whip383's Avatar
Default Re: How do I tap the wire so my XM stays on without the ignition being on? (whip383)
ttt
Old 06-21-2002, 04:35 AM   #3
_Nomad_
CF Senior Member
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11
_Nomad_'s Avatar
Location: Frankenstein never scared me. Marsupials do, because their fassst…and they DART, THAT'S crazy!
Yes, in the footwell of the C5, the wire harness next to the big shiny metal box. Yellow is switched power and Orange is always hot. You will want the switched power (Yellow) to do what you want.
Good luck. :seeya
_Nomad_ is offline   Reply With Quote
Old 06-21-2002, 11:54 AM   #4
David_Levin
CF Senior Member
You need to clarify.
Do you want it on all the time? Or with the key in acc position? Or under RAP power?
Also, what type of xm? RF modulated? Do you still have your factory HU?
[Modified by David_Levin, 7:55 AM 6/21/2002]
David_Levin is offline   Reply With Quote
Old 06-21-2002, 01:40 PM   #5
JT-C6
CF Senior Member
Cruise-In IV Veteran
St. Jude Donor '03-'06-'08-'10-'11
Support Corvetteforum!
JT-C6's Avatar
Default Re: How do I tap the wire so my XM stays on without the ignition being on? (David_Levin)
I have my XM tied to the ACC power. Do you know of a RAP power source that I can tap into in the passenger footwell where I'm already located?
JT-C6 is offline   Reply With Quote
Old 06-21-2002, 02:25 PM   #6
whip383
CF Senior Member
whip383's Avatar
Default Re: How do I tap the wire so my XM stays on without the ignition being on? (JT-C5)
Thanks guys, its the yellow wire by the passenger footwell.
chan :cheers:
Old 06-21-2002, 02:32 PM   #7
David_Levin
CF Senior Member
Perhaps if you're still using the factory head unit. You need the factory HU to interpret the rap on/off commands.
How much current does the XM pull. You might be able tap the power being switched by the Bose relay (which also powers the door woofer amps). If the current is high you could use the trigger from the HU (or the bose switched power) to trigger a secondary relay.
Don't have a service manual here. What is the size of the fuse feeding pre-switched power to the Bose relay? If it's big (like 10 amps) there's probably 2-3 margin. Could measure the current during operation. Could also tap it, and if the fuse blows you're pulling too much.
I tapped the headlight relay to control the HU dimmer. Take a look at:
http://forums.corvetteforum.com/zerothread?id=285329
(bottom of thread)
[Modified by David_Levin, 10:35 AM 6/21/2002]
Old 06-22-2002, 05:48 PM   #8
whip383
CF Senior Member
whip383's Avatar
ill take a look, thanks david
chan
Reload this Page How do I tap the wire so my XM stays on without the ignition being on?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
