Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-20-2002, 06:44 PM   #1
guywade
CF Senior Member
guywade's Avatar
Default antanae doesn't always go up??
but it's not the nylon zip inside the mast, something with head unit possibly? seems like when head unit warms up or gets hot , i.e. i'm listening to cd for a while, i eject cd, then press my power on button to raise antanae, alot of the times the antanae goes up 3 to 4 inches then drops back down , changed head unit to another alpine and it still does it, could it be something in the wiring, from which the head unit turns on and starts the antanae up process?? bad ground when hot or something :confused: :confused:
i don't think i need another head unit, hopefully ! :D TIA
guywade is offline   Reply With Quote
Old 06-21-2002, 01:02 AM   #2
92TripleBlack
CF Senior Member
92TripleBlack's Avatar
Default Re: antanae doesn't always go up?? (guywade)
It could be a bad antenna relay or dirty antenna. I'd replace the relay and clean the antenna. I use pedros bicycle chain lube on mine. Doesn't attract dirt, lubes and cleans. The relay is cheap and you should be able to get one from Radio shack if its a standard type relay. I never had to deal with replacing one so I'm not sure. Its located under the carpet in the rear of the storage compartment driver's side.
92TripleBlack is offline   Reply With Quote
Reload this Page antanae doesn't always go up??
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
