Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-20-2002, 12:26 AM   #1
LD85
CF Senior Member
LD85's Avatar
Send a message via Yahoo to LD85
Default Pulled the bose in the door, 6.5 / 3-ways?
Are 6.5's ,,, 3-ways the way to go for the doors?
Or compoenents? If I go with components I would put them in the hole next to probably 5.25"s.
Thoughts please cause, this is my last go round with this crazy stereo system. BTW I have Infinfit 6x9's in the rear.
1985 C-4
LD85 is offline   Reply With Quote
Old 06-20-2002, 12:59 AM   #2
92TripleBlack
CF Senior Member
92TripleBlack's Avatar
Default Re: Pulled the bose in the door, 6.5 / 3-ways? (ld85)
Never go three way speakers, or triax, unless they are 6x9 or bigger. It is a marketing technique. The extra tweeter does nothing to make it sound better but does block alot of midrange.
In order of preference: Good quality seperates, 6.5 coax, 5.25 coax. It depends on how much power you have and how much you want to spend.
92TripleBlack is offline   Reply With Quote
Old 06-20-2002, 01:06 AM   #3
LD85
CF Senior Member
LD85's Avatar
Default Re: Pulled the bose in the door, 6.5 / 3-ways? (92TripleBlack)
75x 2 is the power for the speakers and $200 is the budget. It sounds like 5-1/4 components would be the way to go.
FYI, my dash speakers that I took out were 4x6 Infinfity speakers with a .75 tweeter and a 4" mid.
Old 06-20-2002, 01:24 AM   #4
92TripleBlack
CF Senior Member
With that power, a set of coax is in order. You will be pressed to get a high end set but it is doable. Try looking for one on ebay, at shops as leftovers or discontinued brands, etc. That's how I got my Bostons. 5 1/4 or 6 1/2 would both work though the 5s would fit easier and the 6s would probably sound better.
Old 06-21-2002, 05:58 AM   #5
_Nomad_
CF Senior Member
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11
_Nomad_'s Avatar
Location: Frankenstein never scared me. Marsupials do, because their fassst…and they DART, THAT'S crazy!
5.5" to 6.5" will requier a little cutting on the door pod to get it in.
Depending on the mounting depth of the 6.5” it may require building a baffle.
_Nomad_ is offline   Reply With Quote
Old 06-21-2002, 06:00 AM   #6
Kale
CF Senior Member
Kale's Avatar
Default Re: Pulled the bose in the door, 6.5 / 3-ways? (The^Nomad)
JL XR650 will be the best bang for your buck around $200..
Kale is offline   Reply With Quote
Reload this Page Pulled the bose in the door, 6.5 / 3-ways?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
Very Bad News- (Long) satyr7777 C4 General Discussion 31 11-01-2004 01:23 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
