Sponsored by: DashLynx
Sound deading and insulation install new GS coupe
Old 03-27-2013, 06:33 PM
C130herc
C130herc's Avatar
Default Sound deading and insulation install new GS coupe
Am I missing something, I have been reading posts for the last hour. I just ordered the vette nuts.net C6 Premium Insulation Layer Ensolite Pre Installed on Foil kit.
Do I need to order raam mat bxtII or an equivalent to complete the deading process? If I understand the posts correctly, to have the best combination of insulation, sound deading and heat suppression you need to do all three layers. Order the bxtII as well, yes or no? Thanks
Old 03-27-2013, 07:45 PM
Buddy A
Buddy A's Avatar
Yes. For best results you will need the dampening, as well as insulating. Ensolite and Raamat will be good. I put the insulation on top of those two and it was pretty thick. But does do the job.
Old 03-28-2013, 10:52 AM
alxltd1
alxltd1's Avatar
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
I sent you a PM with a site that describes the basics of sound insulation and techniques. It really is a 3 step process of dampening vibrations, blocking sound, and absorbing sound. Thermal insulation sometimes is a byproduct though there are products to specifically do thermal, or sound, sometimes both. researching first will pay off in the long run. Just remember there is no free lunch. To do it and get the maximum results will add weight to the vette. That may or may not be an issue for you, so you have to decide. Good luck.
Old 03-29-2013, 09:11 AM
ch47d1sg
ch47d1sg's Avatar
Just did my carbon custom and did not use the raamat only the package from Mark with the ensolite. I achieved a 17 db reduction in interior noise. You will have to take your time installing, do it right, do everything to include your doors, and you will get an improvement. Expect some fitment issues with a two layer system (vettenuts) but they will be minor. Add more layers and you will have significant more issues but would get a better db reduction.
Old 03-31-2013, 06:44 PM
Buddy A
Buddy A's Avatar
If you are going to go through the trouble of taking everything out of your car to install anything at all. Do it right while you are there. It is a lot of work to get to that point. Might as well put the good stuff in there. It is nice when you close the door after it is done right. The solid thud of a well insulated and dampened vehicle
To Sound deading and insulation install new GS coupe
Quick Reply: Sound deading and insulation install new GS coupe
