Lost xm option on radio
I HAVE A NAV UNIT WITH BOSE HAD XM RADIO AND NOW THE OPTION IS GONE NOTW JUST HAS FM 1 FM 2 AM AND CD BOX FOR XM IS GONE. DOES ANYONE KNOW WHAT COULD HAVE HAPPENED? hOW CAN I GET MY XM OPTION TO WORK AGAIN SINCE IT IS NOT DISPLAY ED ANY LONGER? tHANKS IN ADVANCE
The box may have come unplugged. Unless you have a vert it's located on top of the drivers side rear wheel hump, up under the plastic ledge when you pull out the carpet.
You may get lucky and get it back if you pull the radio fuse for a few minutes. It's in the footwell labeled as RDO/VICS
