Question about the remote wire
I am installing a Pioneer X930BT as well as a 4 channel amp and sub amp. I am ready to hook up the remote wire and want to ensure that I splice into the blue and white wire on the HU wire harness. Also, do I need to splice at the other end to run the remote power to both amps? I appreciate the feedback. Just don't want to make a mistake.
The remote wire is just a low voltage wire that gives a binary on/off signal.
I've never tried it before, but you can probably daisy chain a wire from one amp to the other one.
The blue/white is the amp remote wire, just make sure you don't use the antenna control wire by mistake (they're both blue/white).
You can jumper the trigger wire to as many amps as you want as long as it's just a trigger signal, don't try to use it as the actual power source to something (fans, lights, etc...).
Thanks guys. I only have 1 blue and white wire but it is wired this wayhttp://forums.corvetteforum.com/audio-electronics/2692118-pics-and-info-on-wiring-a-roem-vet1.html
I had Dennis a DD Mods do this for me. Now I'm definitely not sure which wire to use.
Thanks guys. I only have 1 blue and white wire but it is wired this way http://forums.corvetteforum.com/audi...roem-vet1.html
Connect the new HU yellow and black power wires through the roem. Connect the new HU red power wire to a switched source. The rest of the roem wires don't matter if you have new amps and speakers.
Run fused amp power wires from battery and frame ground to amps. Connect the new HU blue/white amp remote (possibly labeled P.Cont) to the trigger terminal on the amps (usually between the big power connections).
