Sponsored by: DashLynx
need help with C6 speaker/amp upgrade
Old 03-18-2012, 04:40 PM
angelmanuel
angelmanuel's Avatar
should i ground the radio's chassis to the same place i ground the amp?
Old 03-18-2012, 04:54 PM
markcz
markcz's Avatar
It's up to you. I usually just use the oem ground wire in the harness.
Old 03-18-2012, 05:14 PM
angelmanuel
i am worried about ground loop and alternator whine. someone suggested that in another thread. do you think it will work?
also, would it be ok to install the amp in one of those vette bins?
Old 03-18-2012, 05:59 PM
markcz
markcz's Avatar
Grounding everything at the same bolt sure cant hurt
I wouldn't install any amps in a location that didn't get some type of ventillation.
Old 03-18-2012, 06:05 PM
angelmanuel
i just dont know where to install the damned thing
Old 03-18-2012, 06:16 PM
markcz
markcz's Avatar
How about bolting it to the top of the vette bin?
Or maybe attach a piece of 1/4" MDF to the bottom of the bin and have it stick out towards the rear of the car enough to mount the amp on top of it.
My next setup will most likely have two amps, DSP processor, and active crossover all on the hatch floor at the rear wall. My plan is to bolt everything to a piece of 1/4" MDF that's hidden under my Lloyd's mat. I'm already planning on hacking off the drivers side corner of the mat for my sub box, so a few more holes in it won't matter
Old 03-18-2012, 06:34 PM
angelmanuel
that's a good idea. i guess i can start at the bottom and if it overheats
then move it to the top.
Old 03-18-2012, 08:32 PM
angelmanuel
how far away from speaker wires or any other wires should the RCAs be?
Old 03-18-2012, 08:57 PM
Orange06
Orange06's Avatar
The main thing with the wires is to keep your amp power wires away from your audio signal wires. If they have to cross, try to cross them at 90 degrees.
When I did the install in my coupe, I ran the amp power along the passenger door sill, speaker wire to the passenger door along the transmission tunnel on the passenger side, RCAs to the back along the drivers side of the tunnel, and speaker wire for the drivers side door along the drivers side door sill.
Quick Reply: need help with C6 speaker/amp upgrade
