Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
Audio/Electronics
Stereo System Installation Info, Amplifiers, Subwoofers, Radar Detectors, Police Scanners, and CB Radios for the Corvette Sponsored by
Optima Batteries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-01-2012, 12:58 PM   #1
billla
CF Senior Member
Support Corvetteforum!
billla's Avatar
Send a message via MSN to billla
Default C5 Z06 CD Changer installation questions
Just got a great deal on a C5 CD changer; I have the unit, mounting brackets and hardware
Two questions:
1. Is everything there in the Z06 to mount the changer? I.e. are the holes and nut inserts there or am I getting out a drill?
2. Is there an aftermarket source for the cable to the head unit? I understood the Z typically doesn't have this cable run.
THANKS!
billla is offline   Reply With Quote
Old 03-01-2012, 06:02 PM   #2
markcz
markcz's Avatar
The COR-Har is the cable you need. Click here
I added one and just used foam to wedge it in the cubby. If you drill make sure you don't go too far through the plastic, but I'd suggest epoxy rather than drilling.
markcz is offline   Reply With Quote
Old 10-29-2012, 10:55 PM   #3
Andy Boyuka
Junior Member
Default cd installation
Quote:
Two questions:
THANKS!
I am trying to install a OEM 12disc.I ordered a wire harness from a corvette salv yrd. i think they sent me way too much. is it possible for you to discribe the wire harness for me?
Andy Boyuka is offline   Reply With Quote
Old 10-30-2012, 09:52 AM   #4
markcz
markcz's Avatar
If the cor-har is what you have it will have 2 plugs on one end, IIRC one with 3 wires and one with 4 wires. On the other end it will have a flat 10 pin plug. Cable length is around 12' long.
Reload this Page C5 Z06 CD Changer installation questions
Tags
01, buy, c5, cable, cd, changer, corvette, external, install, location, mounting, player, receiver, wiring, work
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
