Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
Audio/Electronics
Stereo System Installation Info, Amplifiers, Subwoofers, Radar Detectors, Police Scanners, and CB Radios for the Corvette Sponsored by
Optima Batteries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-12-2012, 02:18 AM   #1
Badd LS6
CF Senior Member
Badd LS6's Avatar
Default adding sub and amp to 04Z
Hey guys i'm going to be adding a sub n amp to my 04 z06. I will be using the stock head unit. I've tried searching through the audio section and read that i can not use a high-low converter on the speakers due to the bose processor not sending low frequencies to the speakers..Atleast thats what they said about the rear speakers..i dont believe my 04z has rear speakers?? i never looked lol...
I saw someone mentioning using the SVEN2...http://www.amazon.com/Peripheral-SVE.../dp/B000GAWS4A
Does anyone have any tips or write ups on how to accomplish putting a sub n amp in a c5z with using the stock headunit? any help or tips would be greatly appreciated! Thanks!
Badd LS6 is offline   Reply With Quote
Old 01-12-2012, 04:22 PM   #2
markcz
markcz's Avatar
Get yourself an AOEM-Vet1 from Dennis
I believe he has a link with DIY instructions, but it's pretty simple. He'll be back once CES is over.
markcz is offline   Reply With Quote
Old 01-12-2012, 05:25 PM   #3
Badd LS6
CF Senior Member
Badd LS6's Avatar
i was reading up on that as well..isn't that just if i wanna swap headunits?
Old 01-12-2012, 05:35 PM   #4
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
roem is to swap
aoem is to add an amp
pentavolvo is offline   Reply With Quote
Old 01-12-2012, 05:41 PM   #5
Badd LS6
CF Senior Member
Badd LS6's Avatar
Ahhhh..is there any write ups on how to install?
Old 01-12-2012, 06:10 PM   #6
pentavolvo
CF Senior Member
pentavolvo's Avatar
its literally plug and play but there may be some floating around
Old 01-12-2012, 11:45 PM   #7
markcz
markcz's Avatar
Dash Removal DIY. Pull out the radio, plug in the AOEM, reassemble dash
The AOEM plugs in between the radio and original wiring harness, it will give you 4 RCA line-level connections and an amp trigger wire.
Amp needs new power wire run to battery (fused please), and ground to nearest convenient point (kits avail for $20).
Run 'trigger wire' and 1 or 2 RCA cords from radio to amp (depending on setup).
All that's left is
Do you have the sub/box/amp yet?
Old 01-13-2012, 03:06 AM   #8
Badd LS6
CF Senior Member
Badd LS6's Avatar
sweet i thought i would of had to do some wiring.. I'm not new to installing systems.. Just wasn't too sure about the vettes and read some horror stories on here. I already ran the power wire and ground.. Just gotta do the AOEM and trigger wire..
I have a sony 1200 and a 12" kicker L5 that i will be using for now..Going to replace the L5 with a L7. I'll be sure to add pics once i'm done .. hopefully i have room left over in my trunk with the sub,amp and 2 nitrous bottles
Old 01-13-2012, 11:28 AM   #9
raydawg357
CF Senior Member
raydawg357's Avatar
Ray Jolivette Raydawg357
Once you pull your OEM radio, the power harness is made up of 3 sections. In the bottom section of the harness, you will find your rear speaker wires. They are: Brown (RL+) and yellow (RL-), Blue (RR+) and Lt Blue (RR-) These are the the wires you need to tap into for your signal. When splicing into wires I like using the Military Splice method. You will have to tap into your fuse box for the remote turn-on power for your amp.
Click the image to open in full size.
raydawg357 is offline   Reply With Quote
Old 01-13-2012, 05:01 PM   #10
markcz
markcz's Avatar
The center tub is perfect for a sub, if that's not where you stashed the nitrous.
Many people mount their amps directly to the rear vertical wall in the trunk, it's a great spot.
Quote:
The AOEM interface will do all of this for him
Reload this Page adding sub and amp to 04Z
Tags
adding, addvet1, amp, amplifier, c5, cables, corvette, electrical, methods, military, rca, rear, speaker, splice, splicing, trigger, wires, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
