Dimmer on C6 and Pioneer Z130BT
Trying to install a Pioneer Z130BT in a 2011 GS. I can't get the dimmer to work. I have tied the orange/white wire from the HU to the Gray/Black on the traction control button as I've read in other posts and still cannot get the HU to dim or go into night mode when the headlights are on. Any suggestions?
Is it dark outside?
The dimmer circuit doesn't exactly operate in conjunction with the headlights, it uses it's own sensor (I believe on the dash near center speaker, but not sure about that).
You have to catch the dimmer wire from behind your HVAC controls. It should be yellowish or cream in color. Test it with a DMM to be sure.
just dealt with dimmer issue on my c6 Monday. had wired GMOS4 adapter properly and dimmer did not work. 30 mins with Crutchfield tech support resulted in solution. Tapped wire on HVAC controls to radio harness orange/white illumination wire. Works properly now. There are three harnesses connected to back of HVAC. You want the right most (closest to passenger) harness. looking at female side of harness, tap the gray/black stripe wire in the right most(passenger) lower corner of connector. I'll find the pic...says a thousand words...
