after istall issue
after istall issue
After I installed my stereo I dont have heat coming at the drivers side feet. The passenger has it did I knock something loose? If I place my hand in the bottom of the dash its blowing but not from where it used to. Is there a hose or something? thanks guys
With any luck your problem is just that your HVAC damper motors need to be 'recalibrated'. With the car running and AC on, pull/reinstall fuses #18 & 27 in the passenger floorboard. The motors should reset when power is reapplied, if you're lucky.
If that doesn't work I'd pull the dash and verify that the HVAC control box plugs are all snapped in completely.
They motors are changing its just I think a rubber or plactic hose is not connected from the under dash area to where it comes out at your feet. The passengers side is fine, not the drivers. They switch from vent, defrost and floor. Is there such a hose? or part
