Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-07-2002, 09:47 PM   #1
FarmerBob2001
CF Senior Member
Default Anyone mount their tweeters on the dash?
I'm going to be having a new system put in my C5 soon, and will be getting components for the front. I'm wondering if the stock location is the best place for the tweeters.
I'm thinking that placing them on the dash, far forward, and to the sides might be a good location (pointing towards the opposite passenger). Basically, right beside the A-pillar plastic's most forward point, right where the windshield meets the dash. Maybe an inch or two back if necessary.
Has anyone done this? The reason I'm thinking about this location is that the tweeters should not be blocked by my or my passenger's legs, arms, etc. Both tweeters should be unobstructed, or nearly so, for both passengers.
The downside would be that they will be a pretty good distance from the mids. What's worse, having them a few feet from the mids, or having them blocked by body parts? Are there any issues with having them so near the windshield?
Thanks for your opinions.
FarmerBob2001 is offline   Reply With Quote
Old 05-07-2002, 10:02 PM   #2
JoeyG
CF Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
JoeyG's Avatar
Default Re: Anyone mount their tweeters on the dash? (FarmerBob2001)
Sounds great with every type of music. Also I'm running enough power that the sound stage really isn't that noticable of an offset/effect. However on one or two tracks from the Jamiroqui CD when he's going into a solo (no music) followed by the backup artists, there seems to be a slight pull from front/ center to the sides. However I'll be adding another fill tweeter in the kick panels to cure this problem. :yesnod: :cheers:
JoeyG is offline   Reply With Quote
Old 05-07-2002, 10:05 PM   #3
FarmerBob2001
CF Senior Member
Default Re: Anyone mount their tweeters on the dash? (JoeyG)
Looks like yours are mounted in the middle of the dash. Any particular reason you chose that location vs. the outside edges of the dash? Seems like you would lose the stereo effect for the frequencies the tweeters handle with them both in the middle like that.
Old 05-08-2002, 12:01 AM   #4
JoeyG
CF Senior Member
JoeyG's Avatar
Yep, I wanted to bring the soundstage/level up to eye level instead of around the knees. The install has created a "good center channel effect", however, like stated in the previous post I'll be adding a lesser powered set of tweeters to the kick panels to compensate for frequency shift. Other than that my door mid-bass and midrange handle the job pretty darn well.
Reload this Page Anyone mount their tweeters on the dash?
Tags
dash, middle, tweeters
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
I Finished My Sound System AGENT 86 Audio/Electronics 22 03-20-2005 11:29 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
