I know this topic may have been addressed already, but............ I purchased a 12 disc CD changer and a wiring harness for my 02 Vert. I have installed the changer in the rear middle tub and am ready to proceed with the wiring. I have a harness that one end obviously plugs into the changer and the other end into the plug(s) in the passenger footwell are. I seem to recall in my reading of the wiring install that there are two plugs to access in the footwell, but the other end of the harness I have only has ONE plug. What am I missing? Do I have the wrong wiring harness? Is my assumption correct in that there are two plugs to connect in the footwell area? There were no instructions included with the changer for a Corvette install. Help for this novice is appreciated.
one of the plugs in located next to the fuse panel on the floor, the other one should be taped to the harness above the BCM (it's located just to the left of the fuse panel).
look around really good, you'll find them!
they will be the only plugs that the changer harness will plug into. :cheers:
Thanks RPOZ4Z. Now, that you have confirmed there are two plugs in the footwell. There is only ONE plug on the end of the wiring harness. How do I plug two into one? Do I have the wrong harness?
Ok, now that your on the subject of CD changer installs. Can I install a stock CD changer into a 2002 Z06?? Will It work??? If so what do I need to purchase and about how much will it cost? PLEASE let me know.
