Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-06-2002, 03:36 PM   #1
Kale
CF Senior Member
Kale's Avatar
Default Deflex Pads... Anyone using them?
Any comments on Deflex pads before I buy a set?
Kale is offline   Reply With Quote
Old 05-06-2002, 07:45 PM   #2
_Nomad_
CF Senior Member
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11
_Nomad_'s Avatar
Location: Frankenstein never scared me. Marsupials do, because their fassst…and they DART, THAT'S crazy!
Default Re: Deflex Pads... Anyone using them? (Kale)
Hi Kale, it’s me Nomad :D
I made another reply over at Sounddomain for you, check it out and let me know the answers to the questions I asked. I will be able to help you further. ;)
Deflex pads will help with resonance and might be a good idea in your case Kale. :yesnod:
Good Luck! :seeya
_Nomad_ is offline   Reply With Quote
Old 05-06-2002, 07:54 PM   #3
Kale
CF Senior Member
Kale's Avatar
Default Re: Deflex Pads... Anyone using them? (The^Nomad)
unfortunately, i just found out I can't get them in there. Not enough clearance :( :( :(
Old 05-06-2002, 08:14 PM   #4
_Nomad_
CF Senior Member
_Nomad_'s Avatar
BUMMER!
Hey have you stuffed the enclosure with polly fill yet? Every little bit counts LOL! :yesnod: :)
Old 05-06-2002, 08:19 PM   #5
Kale
CF Senior Member
Kale's Avatar
thought about it. hehehe. Im going to move the 6.5's to the rear of the car just for poopies and grins.
Old 05-06-2002, 08:23 PM   #6
_Nomad_
CF Senior Member
_Nomad_'s Avatar
What 6.5’s are you running? Also, have you tried the carpet-padding trick yet? We need to come up with a solution that will keep those mids up front where you need them for staging. We’ll figure it out LOL! :lol: :yesnod:
Old 05-06-2002, 08:34 PM   #7
Kale
CF Senior Member
Kale's Avatar
Focal Utopia. :yesnod: I like them a lot, but my "listening platform" isn't so hot!
Carpet padding trick?
[Modified by Kale, 5:34 PM 5/6/2002]
Old 05-06-2002, 08:51 PM   #8
_Nomad_
CF Senior Member
_Nomad_'s Avatar
After putting SEVERAL layers of Sound dampening sheets on the door frame and door panel, put about Ľ” carpet padding between the door panel and door frame. The padding absorbs a lot of resonance and rattles caused by it. Also stuff the enclosure with as much polly fill as you can, even if it is just a little.
Have you tried putting the mids and tweets in the dash and the midbass in the doors? I explained my front stage setup in another post here. Sorry don't know how to place link to it but it is from someone talking to you about tweets in his doors and he can't hear them. Anyway, that setup works pretty good for me. ;)
Old 05-06-2002, 08:57 PM   #9
Kale
CF Senior Member
Kale's Avatar
I have the two way Focal set.
The imaging is perfect.
the car sucks. :lol:
[Modified by Kale, 5:58 PM 5/6/2002]
Old 05-06-2002, 09:01 PM   #10
_Nomad_
CF Senior Member
_Nomad_'s Avatar
Add a 2-way 4" comp set in the dash and keep the 6.5" Focals in the doors?? Would be good sound staging. :D
Old 05-06-2002, 09:03 PM   #11
Kale
CF Senior Member
Kale's Avatar
lol
i dont think i coudl do better as far as sound staging than I have.
The 165 utopia set is LOUD. It will make my ears bleed and 3/4 volume.
I'll probably make some fiberglass panels to run the 6.5's in the late c4
who knows..
the idea is that the late c4 doesn't have door mounts for speakres, just baby mounts in the frame rail.
[Modified by Kale, 6:04 PM 5/6/2002]
Old 05-06-2002, 09:08 PM   #12
_Nomad_
CF Senior Member
_Nomad_'s Avatar
Ahhh yes, fiberglass pods should do the trick. Good luck. :)
HOLY SHEIT! 20,000 posts Kale?!?!? LOL! WOW! :lol: :lol: :yesnod: :D :cheers: :p:
Old 05-06-2002, 09:10 PM   #13
_Nomad_
CF Senior Member
_Nomad_'s Avatar
Yeah my sister has a '95 Vette and I hate those tiny enclosures on the frame rail. But they are workable.
Old 05-06-2002, 09:15 PM   #14
Kale
CF Senior Member
Kale's Avatar
Forum = Chatroom.
Old 05-07-2002, 03:15 AM   #15
mrkln
CF Senior Member
mrkln's Avatar
Hey Nomad, what Image Dynamics speakers are you using? I am currently building a box for an IDMAX for my C5.
:cheers:
mrkln is offline   Reply With Quote
Old 05-07-2002, 07:46 PM   #16
_Nomad_
CF Senior Member
_Nomad_'s Avatar
Default Re: Deflex Pads... Anyone using them? (mrkln)
:cheers:
Right now I have Image Dynamics CXS62, the 2-ohm 6.5” component set. The subs in my C4 are two Rockford Fosgate RFP3810 10” subs. Wired in parallel at 4-ohm mono.
I plan on putting a single IDMAX 12” sub in my C5 also. The IDMAX is great for both SQ and SPL. Gotta love it! :D
:cheers: :yesnod:
Reload this Page Deflex Pads... Anyone using them?
Tags
deflex, pads
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
