Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
Audio/Electronics
Stereo System Installation Info, Amplifiers, Subwoofers, Radar Detectors, Police Scanners, and CB Radios for the Corvette Sponsored by
Optima Batteries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-02-2011, 11:06 PM   #1
Mike Green9
CF Senior Member
Mike Green9's Avatar
Default C6 Crackling Door Speaker
The RHS door speaker in my 3LT '08 Bose equipped C6 is beginning to crackle. It appears to be the powered 10" one. The crackling is especially noticeable on low quality recordings, and is getting worse.
I have already replaced all the 3.5" with Boston Accoustics.
In the future, I do want to replace the whole system with a Kenwood head unit and higher end speakers. However, I am wondering short term if I should bother to replace the 'crackler'. (It does seem like throwing good money after bad.)
My question - is there a non Bose direct replacement for the 10" Bose powered door speaker? If not, where can I buy the Bose replacement speaker, and approximately how much would it be?
The 3 year portion of my GM warranty has expired .
Thanks,
M...
Mike Green9 is offline   Reply With Quote
Old 11-03-2011, 10:05 AM   #2
EVRose
CF Senior Member
EVRose's Avatar
Keep an eye in the for sale section. I've seen them in there a lot and cheap. I actually gave mine away for free.
EVRose is offline   Reply With Quote
Old 11-04-2011, 07:19 AM   #3
tampatopless
CF Senior Member
Support Corvetteforum!
tampatopless's Avatar
I have the same problem and question.
tampatopless is offline   Reply With Quote
Old 12-11-2011, 08:09 PM   #4
jbauer3
Junior Member
Default Crackling speakers
My 05 with the nav system has a crackling sound even when the stereo is turned off. It happens when the car is moving and any bump or turn and I hear the crackling. I can't narrow it down to one specific speaker either. I don't know if this has anything to do with the poor quality audio I an experiencing. By that I mean the volume isn't able to get very loud at times and the bass is terrible. Has anyone been able to change the 10" door speakers?
jbauer3 is offline   Reply With Quote
Old 12-18-2011, 05:14 PM   #5
BobST1100
CF Senior Member
BobST1100's Avatar
I have a '06 w/3LT package. I have a similar problem with crackling and popping sound coming only from my front right speaker whether the radio is on or off and like jbauer3 the volume doesn't regulate the level of popping sound. Also from time to time I loose the bass from that speaker, then it kicks in only to go out again.
Speakers are passive devices, meaning they only convert electrical inputs to sound. Now unless the Bose speakers in the 3 LT's have separately powered built-in Amps, the cause of the popping is likely coming either from a spurious output from the power amp (the small door located under the passenger's feet) or the receiver.
Does anyone know if these speakers have separate amps?
Last edited by BobST1100; 12-18-2011 at 05:16 PM. Reason: To further clarify content of thread
BobST1100 is offline   Reply With Quote
Old 12-18-2011, 10:35 PM   #6
Mike Green9
CF Senior Member
The 10" Bose door speakers have powered amps built right in.
This is my problem, I can't just swap in better quality speakers.
M...
Old 12-19-2011, 08:48 AM   #7
BobST1100
CF Senior Member
BobST1100's Avatar
M...
Is this in addition to the power amp under the passenger foot plate? That seems strange to feed the output of a power amp into a 2nd power amp ?
Old 12-19-2011, 09:14 AM   #8
Mike Green9
CF Senior Member
As far as I know, the 10" door speakers have built in amps. I will see if my shop manuals have any details and get back to you.
Check in the audio section. Let me know if you get any more info.
Thanks,
M....
Old 12-19-2011, 11:03 AM   #9
TBonez
2005 Beast
TBonez's Avatar
Dude, I'm getting mine completely taken out and putting JL Audios in my doors so I will have the 2 Bose if you want to buy em.... let me know...they work great.
TBonez is offline   Reply With Quote
Old 12-19-2011, 12:54 PM   #10
Mike Green9
CF Senior Member
Here is the door speaker schematic for my '08 3LT no Nav.
Click the image to open in full size.
There appears to be 12 volts going to the speakers along with speaker level lines. This implies the speaker has a built in amp.
M...
Old 12-20-2011, 07:54 AM   #11
BobST1100
CF Senior Member
BobST1100's Avatar
Thanks,
M....
Hi Mike, thanks for the schematic. Yeah I see it shows 12v to the speakers. This morning I went over to the Bose web site and saw a brief video on their technology.
http://www.bose.com/controller?url=/..._efficient.jsp
Old 12-20-2011, 10:23 AM   #12
Thrash
CF Senior Member
Thrash's Avatar
You can't spell BOSE with out BS ...
Thrash is offline   Reply With Quote
Reload this Page C6 Crackling Door Speaker
Tags
c6, c6corvettedoorspeakers, corvette, crack, crackel, door, gm, popping, removal, shorting, speaker, speakers, turn, turned, wheels, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
