03-25-2002, 06:21 PM
CF Senior Member
Ft Myers Area Coordinator
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
what wire do i need to power my amp????
when they installed it, they used an existing wire. now it isnt enough, they told me 10 or 8, and wanted to charge me $69 to run a wire which is :bs
Im gonna do it myself, just need to know what to use
03-25-2002, 07:14 PM
CF Senior Member
Re: what wire do i need to power my amp???? (My 95)
How much power is your amp pushing?
03-25-2002, 07:27 PM
CF Senior Member
Re: what wire do i need to power my amp???? (mrkln)
thats a good question.....I have to look
03-25-2002, 08:47 PM
CF Senior Member
its a small one....50w x 2....powers 2 jl 8's
03-25-2002, 09:26 PM
CF Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
10 gauge would be adequate, fuse at 30 amps max. 8 gauge would be better fuse at 40 amps max.
03-25-2002, 09:30 PM
CF Senior Member
Re: what wire do i need to power my amp???? (JoeyG)
03-25-2002, 09:51 PM
CF Senior Member
Use the same size power and ground also. :cheers:
03-26-2002, 06:03 PM
CF Senior Member
And get a high strand wire like Monster, phoenix gold, etc. Don't use wire with a low strand count. It will probably cost about $.25-.50 a foot. Run your ground to the frame as close as possible and keep the fuse holder in the engine compartment near the battery.
03-26-2002, 08:36 PM
CF Senior Member
Re: what wire do i need to power my amp???? (92TripleBlack)
04-07-2002, 11:33 PM
CF Senior Member
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11
Location: Frankenstein never scared me. Marsupials do, because their fassst…and they DART, THAT'S crazy!
Go with the 8-gauge, always leave yourself some breathing room. ;)
04-08-2002, 10:36 AM
CF Senior Member
Re: what wire do i need to power my amp???? (The^Nomad)
8 is probably best though 10 is sufficient. If you ever plan on expanding however, go with a 4. YOu can then split off of it later if you want.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
