I have done some more troubleshooting on my problem and I ruled out the subwoofer amp. and speaker.
I have two possibilities now, it's either the bose signal processor or the head unit.
I am leaning toward the signal processor.
does anyone have a bose signal processor just laying around collecting dust?
:D
Re: Update on my bose subwoofer problem.......... (RPOZ4Z)
This is a different description of the symptoms than you stated earlier. If ALL the sources into the HU have the same problem, then it is either the BSP or the sub amp itself.
Since all the people who have replaced their HU in their C5 cannot use the BSP, it is just dead weight under the dash, Get someone to send you one for a test.
Re: Update on my bose subwoofer problem.......... (99HT)
99HT,
yes, it is a different description because I did more troubleshooting on it sunday. thats when I discovered the distorted sound to the left front.
I swapped the sub amp and speaker from the right front to eliminate them as the cause of the problem.
so, now I am left with the BSP or HU.
