Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
Audio/Electronics
Stereo System Installation Info, Amplifiers, Subwoofers, Radar Detectors, Police Scanners, and CB Radios for the Corvette Sponsored by
Optima Batteries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-28-2010, 06:00 PM   #1
speedy77
CF Senior Member
speedy77's Avatar
Default FM reception sucks after install of Kenwood DNX5140
Finally got my total sweep done !!....One thing I haven't been able to get right is the FM reception. It's not even close to the Blose unit.
I have the blue wire on the GMCO / B3 hooked to the power antenna wire from HU (I also had tried the wire for the amp power up...the same). It does get better when I attach the power wire but still poor. I checked the bigger antenna wire seems OK.
Does the ground wires have anything to do with it ? I just have all the blk. wires hooked together but didn't run them to ground. Everthing else works fine on the HU.
Is there an FM setting in the Kenwood 5140 ? I looked through the manual 100 times..nothing.
speedy77 is offline   Reply With Quote
Old 03-28-2010, 07:07 PM   #2
markcz
markcz's Avatar
Quote:
Click the image to open in full size. If you have the module powered with 12v, that's about all you can do. Plastic cars make for bad antennas
markcz is offline   Reply With Quote
Old 03-28-2010, 08:19 PM   #3
Darion
CF Senior Member
Darion's Avatar
I didn't have great reception with the Kenwood I had, but then again my Alpine is really no better.
I had the factory setup in for such a short time I don't know if it was good or not?
Darion
Darion is offline   Reply With Quote
Old 03-29-2010, 10:22 AM   #4
Blackout
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
Blackout's Avatar
Ray Aldrich
Quote:
I only know of the C5 but if the C6 is setup in a similar manner with 2 antenas (one front windshield, one back rear deck both going to a power module) then you have to power up the module with the proper voltage. Markcz has been giving me great information! He is one smart dude on here.
Markcz/OP...do you have the module grounded? You mentioned all the black wires "tied together" but not grounded?
Blackout is offline   Reply With Quote
Old 03-29-2010, 05:43 PM   #5
markcz
markcz's Avatar
In C6 there are 2 antenna modules, both located inside the rear bumper, and both have their own ground, so all you need to connect is the +12v. There is a 'FM Composite Signal' wire that normally connects to the stock radio, but nobody ever confirmed exactly what it does. I believe it's some kind of feedback type system that would tell the modules if the signal is good or bad, telling them if they need more or less amplification, but that's just speculation.
Click here for the antenna schematic.
Old 03-29-2010, 07:27 PM   #6
WB6HRO
CF Senior Member
WB6HRO's Avatar
The composite FM signal is most likely the sum of the two antennas, less prone to fading.
It is also known as Diversity Antenna System using more than one antenna.
Sometimes they polarize one antenna vertical and one horizontal.
The intent is to fill in areas that may flutter due to signal strenth.
WB6HRO is offline   Reply With Quote
Old 04-03-2010, 07:50 AM   #7
crease-guard
CF Senior Member
crease-guard's Avatar
This is correct. The service manuals spell out how this system works. Unfortunately, any aftermarket system won't give the FM composite signal. Our only solution would be to buy an aftermarket antenna or replicate the composite signal circuitry and algorithm used to fine tune the signal.
Jay
crease-guard is offline   Reply With Quote
Old 04-04-2010, 11:22 PM   #8
Jimmy 2 Times
CF Senior Member
i put a metra glass mount antenna under the grill (where the center speaker is) and that greatly improved the signal.
Jimmy 2 Times is offline   Reply With Quote
Reload this Page FM reception sucks after install of Kenwood DNX5140
Tags
06, antenna, bad, composite, corvette, devrsity, dnx5140, fm, glass, install, metra, mount, radio, reseption, review, signal
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
