Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-21-2010, 02:25 PM   #1
andrewdonald1
CF Senior Member
Default 04 C5Z - fuse 22 amp rating?
Gents: I thought I had the additional pigtail down in the passenger compartment area even though I've read that they didn't have them in 2004. Now that I have everything out, I was wrong.
So I am running a 6 post accessory fuse block to land all of my accessories to.
I was going to come off fuse 22 with a fused tap in fitting.
They are only rated at 10 amps.
I am thinking I want the ability to run 20 amps to the accessories fuse box.
Does anyone know the rating of fuse 22?
I haven't pulled the fuse box out to look behind and see if there is wiring to the termination.
Maybe if I want more than 10 amps, I use the fused tap fitting and run it to a 20 amp relay, then run 12 gauge fused wiring to the relay, then run the relayed accessory power into the accessory fuse block.
andrewdonald1 is offline   Reply With Quote
Old 03-21-2010, 02:53 PM   #2
andrewdonald1
CF Senior Member
Never mind. I'll play it safe and run the relay circuit and be done with it.
Reload this Page 04 C5Z - fuse 22 amp rating?
Tags
22, fuse
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
