Quote:
Originally Posted by markcz
Others have made comments about the lights on the adapter not doing anything before.
Plug it in to the dash harness then use a meter on the red and black wires coming out to see if you have power with the car running.
10-4. I'll check after I finish pulling power to underneath the lower passenger dash area.
PS: I ended up mounting up a couple fused power blocks and mounting on velcro up in the area beside the HVAC fan.
One for 12 volt constant, another for 12 volt accessory.
Both have grounding blocks as well.
Though is: I'll mount the xm nav/ipod adapters/camera power adapter underneath the passenger seat for now as part of phase I.
Phase-II I may relocate these modules if I decide to make/modify a low profile box behind the seat to accommodate the amp/crossovers, etc. Either way: I've can accommodate anything I need now for circuits plus I have future expansion, and its all fused. Nice and clean.
I'll try and take a picture today.
