Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-05-2010, 07:44 PM   #1
seether4113
CF Member
Default Speaker wiring question (and H/U)
Hey guys, I'm thinking about changing out the front woofers and 3.5" speakers with a set of components, changing the head unit, and adding an amp/sub. My car has the U66 (non-BOSE) and 1-disc cd player.
I've looked around the sticky and searched the board, but I'm still unclear if my car has a factory amp (I believe so?) If it does, would it be possible to buy an amp that fits where it is and use the existing wires that are already ran to the speakers and just run RCA's to the new amp?
Also, if I'm getting rid of the factory amp (if equipped), what harness(es) would I need to install an aftermarket double din?
Thanks in advance for any help.
seether4113 is offline   Reply With Quote
Old 02-05-2010, 07:51 PM   #2
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
onstar?
i believe there is only one amp that will fit in place of the oem and its an arc mini 2 channel so it wont do speakers and a sub
honestly its super easy to run new wire to the door speakers its not worth hackin the oem wiring to try and use it
if ur car doesnt have onstar u need the peripheral gmco harness
pentavolvo is offline   Reply With Quote
Old 02-05-2010, 08:05 PM   #3
seether4113
CF Member
Quote:
Originally Posted by pentavolvo View Post
onstar?
After seeing all of your responses to others, I was hoping you would respond. No, I don't have onstar. How would that amp be for powering the door speakers and using a mono in the storage compartment for the sub? Also, if I ran new wires to the speakers straight from the headunit, would I just connect the wire straight to the head unit harness and bypass the peripheral harness?
Old 02-06-2010, 07:44 AM   #4
markcz
CF Senior Member
markcz's Avatar
Default C6 ???
The interface adapter just gets RAP controlled power TO the new radio, and the music FROM the radio to the stock amp/speakers (if you still use them). Anything else (new amp, backup signal, dimmer control...) has to be wired outside the adapter.
As said, running new wires to the speakers is very easy, unless you're keeping the OEM amp functional just run new wires.
There are a few more parts you need also, this thread details all of the parts, and this one shows what to do with them.
markcz is offline   Reply With Quote
Reload this Page Speaker wiring question (and H/U)
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
