Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-05-2010, 05:23 PM   #1
bowtiebubba
CF Senior Member
Default Double din install(rivets)
I have been trying to drill out the rivets but note making any progress.Has anyone ground off the rivets?
bowtiebubba is offline   Reply With Quote
Old 02-05-2010, 05:25 PM   #2
SilverSurferC6
CF Senior Member
Send a message via MSN to SilverSurferC6 Send a message via Yahoo to SilverSurferC6 Send a message via Skype™ to SilverSurferC6
Quote:
Bubba,
I am no expert. Perhaps you can provide some info about your model year and more details,
SilverSurferC6 is offline   Reply With Quote
Old 02-05-2010, 06:16 PM   #3
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
sawzall seems to work wonders lol
right angle drill or adapter and high quality bits and patience
pentavolvo is offline   Reply With Quote
Old 02-06-2010, 07:20 AM   #4
bowtiebubba
CF Senior Member
Ive got a right angle adapter on my drill. I can only use small bits,if i go to a bigger bit the drill wont fit in the opening. I hate to have to go buy a new right angle drill.
Old 02-06-2010, 10:40 AM   #5
o2z51
CF Senior Member
o2z51's Avatar
Hey Bowtie i went through 3-4 bits and I didnt even scratch the rivets, I saw zalled em out left the rivets there.
o2z51 is offline   Reply With Quote
Old 02-06-2010, 01:09 PM   #6
bowtiebubba
CF Senior Member
Quote:
I do have a sawsall. Can you cut them out while the cage is in the car? Do you cut between the bracket & the cage?
Old 02-06-2010, 02:00 PM   #7
crease-guard
CF Senior Member
crease-guard's Avatar
Use a dremel and a cutting wheel. Some pop rivets have a harden steel mandrel that often gets left in the center of the rivet. I suspect you are running into that and trying to drill that out will be next to impossible. Tackle it from the side with a dremel.
Jay
crease-guard is offline   Reply With Quote
Old 02-06-2010, 06:18 PM   #8
bowtiebubba
CF Senior Member
I didnt trust myself to use the sawsall,i probably would have cut my dash in half. I found some type of metal grinding heads in my drill bit box that worked great for grinding the heads off the rivets. Took about 30 minutes. Thanks for all the advice guys.
Reload this Page Double din install(rivets)
Tags
corvette, din, double, rivets
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
