Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-03-2010, 07:25 PM   #1
02EBZ06VA
CF Senior Member
02EBZ06VA's Avatar
Default Need some advise for what I want to do.
OK, i have been searching around for awhile and seen many different setups.
So I want to replace the factory speakers. I searched crutchfield and did not see any options. Does anyone what speakers fit. I want to go with an aftermarket HU Double din eventually, but I figure I will start with the speakers for now. I also saw that some are using a partical board piece and doing away with bose all together. I would not mind that set up and does anyone sell a prefabbed piece? Sorry for all of the newb questions. I saw alot of old post and some new, so I am looking for the most up to date info. Thanks for any help
02EBZ06VA is offline   Reply With Quote
Old 02-03-2010, 09:07 PM   #2
Lancejoker
CF Senior Member
Lancejoker's Avatar
Send a message via AIM to Lancejoker
Check the sticky at the top of the audio/electronics forum. There are a ton of installs
Lancejoker is offline   Reply With Quote
Old 02-03-2010, 09:39 PM   #3
02EBZ06VA
CF Senior Member
02EBZ06VA's Avatar
Damn stickys, I used the search function. I did not even think of checking it .
I had a alpine deck and MTX stealth sub in my TA paired with stock monsoon system. I think the monsoon was a much better system than the bose in the Z06.
Old 02-03-2010, 10:15 PM   #4
Lancejoker
CF Senior Member
Lancejoker's Avatar
Yep but you have infinite possibilities with the Vette in comparison to that T/A before you have to do any major custom work
Old 02-03-2010, 11:16 PM   #5
markcz
CF Senior Member
markcz's Avatar
Default Assuming C5Z ???
The speakers in the doors have 'subs' and 3.5" paper twiddlers. Unless you're going to add a real sub in the trunk you can't really remove the door subs, which limits you to just replacing the twiddlers (for now). Many have been happy with Polk db351 or Boston Acoustic S35.
The rears would be 5.25" in a C5Z. Any 4 ohm speaker would work if you want to replace them, but I'd jsut do the fronts for now and wait until you replaced the HU to see what you'll need.
markcz is offline   Reply With Quote
Old 02-04-2010, 08:30 AM   #6
02EBZ06VA
CF Senior Member
02EBZ06VA's Avatar
Thanks, I have pair of elmental design 6.5 duel 4-ohm but I know that they are to big for the rear. Are the rear 5.25" speakers duel voice coil (take 4 wires to hook up)?
Reload this Page Need some advise for what I want to do.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
