02-02-2010, 11:22 PM
CF Senior Member
Need help connecting HU to C6 brake wire??
Hi
Im installing an AVIC Z110BT using an AXXESS GMOS-04. The HU comes up and says the parking brake detect is not connected correctly. Is the blue wire going to the parking brake the correct wire to connect to the HU (green wire).
Mike
02-03-2010, 12:31 AM
CF Senior Member
Cruise-In IX Veteran
avic411.com just bypass it
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
