Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-12-2009, 04:33 PM   #1
Jack Daniels
CF Senior Member
Default What size speakers are in a C5?
I have a 2002 C5 ZO6 and am going to head to Best Buy later on to look at speaker options. I suppose the guys there might know, but can anyone tell me the speaker sizes of all the speakers in the car to make sure they are pointing me in the right direction?
Thanks.
Jack Daniels is offline   Reply With Quote
Old 09-12-2009, 05:39 PM   #2
markcz
CF Senior Member
markcz's Avatar
Are you just replacing the speakers and keeping the stock radio, or is this part of the new HU you've been posting about looking for.
In a C5Z the rears are 5.25", if you keep them functional that's pretty much what you're stuck with.
Front 'twiddlers' are 3.5", but there is also a self powered 'sub' type speaker in each door that's 8". The sub can't really be replaced with an aftermarket equivalent.
What most people do is remove the sub/twiddler assembly and put in a 6.5" coax or component set on custom (or self made) plates, then add a sub in the trunk. In a C5 the center tub is perfect for a stealth sub or bazooka type tube.
If you just want to improve the sound of the stock system, new 3.5" speakers in the doors will do fine. Polk db351 and Boston Acoustic S35 are popular, but any 4 ohm speaker will do.
markcz is offline   Reply With Quote
Old 09-12-2009, 07:04 PM   #3
Jack Daniels
CF Senior Member
Thanks a bunch markcz.
Yes, this is in connection with the new HU. I need the HU for an audio-in port and I read how crummy the stock speakers are so want to replace HU and speakers as well.
But gosh is this stuff complicated.
Let me ask you this--could I simply pay to have the HU and the 3.5" speakers replaced, then down the road make the other upgrades you talked about if I want to improve the sound further? Presumably so.
Old 09-12-2009, 08:03 PM   #4
markcz
CF Senior Member
markcz's Avatar
To swap out the HU and keep the stock speaker setup you'd want an ROEM-Vet1 gizmo.
Swapping the front twiddlers can be done before, during, or anytime after changing the HU.
Old 09-16-2009, 11:21 PM   #5
Jack Daniels
CF Senior Member
Hey, I went to Best Buy and they said I had 6" up front, 8" in rear. That does not seem consistent mark. Were they giving me the stats for a regular C5? Or were they just smoking crack?
Old 09-17-2009, 01:37 AM   #6
markcz
CF Senior Member
markcz's Avatar
They be trippin
The door subs are 8"
The door twiddlers are 3.5"
In verts and Z's the rears are 5.25"
In coupes the rears are 6.5"
Do a search, read through the C5 FAQ, Best Buy is wrong
There are a very few that are different (base model '99 FRC's IIRC), so all that being said, the only way to be 100% sure is to take apart the car and check for yourself
Reload this Page What size speakers are in a C5?
Tags
2003, 99, c5, chevy, corvette, fit, frc, front, size, sizes, speaker, speakers, zo6
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
C5 and general audio FAQ scott_fx Audio/Electronics 172 11-06-2011 10:25 AM
What size speakers will fit in the C5? bhamvett Audio/Electronics 9 04-26-2004 01:54 PM
Best replacement rear speakers for a C5 for under $200???? Let's hear'em! Tormania Audio/Electronics 12 05-10-2002 10:50 AM
I need more bass in my C5 vert - Suggestions please JWSchmidt3 Audio/Electronics 34 09-21-2001 01:35 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
