X-Over Install Location???
Where would is be best to mount to install a x-over in a C5 Vette...
I was looking at either the doors or in the hatch...both to me have pro's and con's but where did you install your x-over?
Pics if you have any?
Re: X-Over Install Location??? (NewVetteLover)
I have done several vette installations, but never in a C-5. Usually you want to put the X-over as close to the speaker as you can. If you could provide more info as to what kind of X-over you have and what other changes you have made, I should be able to help you more. Feel free to e-mail me at corvetteakio@hotmail.com
:cheers:
Berserker
:cheers:
Berserker
Re: X-Over Install Location??? (Berserker78)
:cheers:
Berserker
:cheers:
Berserker
This is a pre speaker instead of pre amp crossover. Mount it where you need to run the least amount of wires. If you have both mid and tweet in the door, mount it in the door as you will have to run only one wire to the door, not two. Double sided tape should be fine. Mount it so it won't get wet from the rain or interfere with the window.
Here's where I put mine. http://temp.corvetteforum.net/c5/timothy2468//box.jpg
Re: X-Over Install Location??? (mrkln)
The amp dedicated to the sub is actually underneath of the box. It fits perfect. The other one is mounted on a 3/4" platform in front of the crossovers on the rear panel of the car.
Timothy2468,
How did you mount your amps?
