Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-18-2009, 08:50 AM   #1
RyanC6
CF Senior Member
RyanC6's Avatar
Send a message via AIM to RyanC6
Default Kenwood 6140 installed yesterday
but, I was trying to "test" the nav and I grounded the ground wire to the wiring harness ground wire and it didnt work, I would still require the car to be stopped to input the nav info.
Only other problem I had -- I didnt connect the blue remote wire and therefore it didn't turn on the factory amps -- I didn't know there were factory amps on the base system on a 2006. Anyway a quick call to the scoche and that was fixed.
Thoughts on the ground wire?
VERY easy install IMHO overall.
RyanC6 is offline   Reply With Quote
Old 07-18-2009, 09:25 AM   #2
markcz
CF Senior Member
markcz's Avatar
I did a google for 6140 bypass and found this thread. Post #24 says to "splice the parking brake safety wire from the DNX's harness into the ground wire on your vehicle's harness" to do the bypass.
markcz is offline   Reply With Quote
Old 07-18-2009, 09:56 AM   #3
TheKomoman
CF Senior Member
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
Quote:
And your issue with the Scosche is ANOTHER reason I beat the drum on the Peripheral modules so hard. Yes, they're more expensive but folks they just work.
TheKomoman is offline   Reply With Quote
Old 07-18-2009, 10:37 AM   #4
RyanC6
CF Senior Member
RyanC6's Avatar
Quote:
It worked great, tones for the door etc.... worth the $$$
Old 07-18-2009, 10:37 AM   #5
RyanC6
CF Senior Member
RyanC6's Avatar
Checking it out now, thanks!
Ohhh, that is what I did, I thought it bypassed the feature where you can use the nav stuff while your moving, I will try the DVD... I wondered how that would work since it knows your speed and how fast your going.....it knows your moving
Reload this Page Kenwood 6140 installed yesterday
Tags
6140, brake, break, bypass, code, corvette, dnx, forum, ground, kenwood, park, parking, peripheral, set, switch, wire
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
