What kind of speakers do you currently hasve in the doors? With the oem subs installed all you'll have room for is 3.5's.
Do you have an amp driving your speakers, or just the HU internal amp? If it's anything other than the HU internal amp I'd guess that you'd have trouble getting the mid/hi volume level equal to the sub level unless you powered all of your speakers from the bose amp.
By looking at the
C6 Schematics, the bose amp is definitely what filters out and sends the low level signal to the door subs, but I'd guess that the signal being sent is just a line level signal. If the door subs are all you want to reinstall, you may want to first try an experiment by sending the sub output of the new HU (along with remote amp trigger and B+) to the door subs to see what happens. If it works, all you'd need to install is the stuff in the doors (and not the actual bose amp).
Quote:
Originally Posted by shane020
I have found someone selling all speakers and amp at a decent price.
Does that mean that you don't still have the ones that came out of your car
