Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-14-2009, 03:58 PM   #1
MoCityc5
Junior Member
MoCityc5's Avatar
Default Removing C5 Rear Enclosure Question
I want to get better visibility around the rear speaker enclosure and it appears that removing the strut is the only way to achieve that. I've seen where everyone says just push the housing up out of the way, but it doesn't move much. Does anyone know if there an easy way to remove or move the housing? Will the grill come out without breaking? The housing seems to be clipped in place right behind the strut mounting position. It moves around enough to unbolt the speakers from the front at the right angle, but I want more and easier access if possible. Thanks for the help.
MoCityc5 is offline   Reply With Quote
Old 07-15-2009, 05:18 PM   #2
RoccoC5
CF Senior Member
RoccoC5's Avatar
The grill pops out. Using a screwdriver (cover the tip with cloth so you don't scratch anything), push the top of the grill downward. The top should pop of the panel.
RoccoC5 is offline   Reply With Quote
Old 07-15-2009, 05:56 PM   #3
MoCityc5
Junior Member
MoCityc5's Avatar
Thanks, that should do it for me.
Old 07-15-2009, 07:19 PM   #4
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
only on a coupe do they pop off
pentavolvo is offline   Reply With Quote
Reload this Page Removing C5 Rear Enclosure Question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
