Quote:
Originally Posted by kev1n
quick question, the rad shack wire, does it get spliced into the XM wires ? Or do you severe the connection completely from the XM unit and wire those up to the ends that go back into the car ? I assume it doesn't get wired into the XM module itself right ?
Splicing it into the wire isn't good enough. The problem with that is you will get sound from both the XM station and your device. You have to sever the connection (as I explained in the instructions).
Correct, it doesn't get wired into the XM module istelf.
Your car needs the audio from the MP3/IPOD. You're basically "replacing" the XM Module with your MP3/IPOD.
