Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-18-2009, 11:02 PM   #1
MYT1G3RSHARK
CF Senior Member
MYT1G3RSHARK's Avatar
Send a message via AIM to MYT1G3RSHARK
Default Radio Install Question
I am trying to test my new receiver. Should it power on with the center console panels still removed or is there some switch that leaves it powered off for some reason?
Perhaps I am already seeing that something is wrong and I should pull it back out?
MYT1G3RSHARK is offline   Reply With Quote
Old 05-18-2009, 11:03 PM   #2
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
should power on fine, i assume u have a c5. go read the FAQ regarding the switched power wiring
pentavolvo is offline   Reply With Quote
Old 05-18-2009, 11:36 PM   #3
MYT1G3RSHARK
CF Senior Member
So simply connecting the power leads from the H/U and the GM harness adapter is no good? I should run my power from the fuse to the radio and not expect to get any power through the harness?
Thanks for your patience.
Old 05-19-2009, 12:19 AM   #4
pentavolvo
CF Senior Member
pentavolvo's Avatar
100% correct. while ur harness may say that wire is switched power it isnt its a data communications wire
also dont plan on ur bose subs working without some custom wiring
Old 05-19-2009, 09:22 PM   #5
MYT1G3RSHARK
CF Senior Member
New issue... I've installed the H/U, have the subs spliced in, and finally have power to it all.
1st question: I have excessive popping from the subs only when they are connected to either the Front Pre-Amps or the Sub-Outs. It happens specifically when you tutrn the volume from zero to 1, when you switch between sources, and when you use the seek function on the Tuner. I am going to re-ground everything... any other ideas or something else I should consider?
2nd Question: The H/U shuts off and comes back on only to shut back off again. It repeats this cycle continuously. I am hoping that the reset ground will help here.
3rd Question: I still have no power on ACC. Must I rewire that as I did the Switch power under the passenger foot rest? Is this the same as the FAQ topic?
Thanks again, you guys are a great resource!
Reload this Page Radio Install Question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Radio install questions? da6speed Audio/Electronics 10 10-05-2004 03:16 PM
Radio Delete Question SizzleChest C3 Tech/Performance 15 06-26-2003 12:07 PM
NX ashtray switch install question... jeffh355 C5 Forced Induction/Nitrous 15 01-18-2003 10:55 AM
Head Unit install question reyderz Audio/Electronics 10 07-13-2002 05:05 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
