Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-04-2009, 05:15 PM   #1
4 KRUSIN
CF Senior Member
4 KRUSIN's Avatar
Default Kenwood Power Supply
I just installed my Kenwood DNX 7120 and have a small question about the constant 12 V supply. There is a 15 Amp fuse on the back of the unit. Do I need to install an inline fuse in the 12V constant supply wire? Can this supply come from the cigarette lighter wire or should I run directly to the battery?
4 KRUSIN is offline   Reply With Quote
Old 04-04-2009, 05:47 PM   #2
RichDash
Junior Member
Send a message via AIM to RichDash
re check your ground and then your accessory with a dmm
RichDash is offline   Reply With Quote
Old 04-10-2009, 12:27 AM   #3
Mister Peebody
CF Senior Member
Mister Peebody's Avatar
Location: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
You don't have to run an inline fuse, but it is cheap insurance. I'd rather my headunit never see that spike in current that would cook your fuse. You can use the cigarette lighter power, but I would go from the battery. I figure the odds of picking up noise is decreased that way, but I am no expert
Mister Peebody is offline   Reply With Quote
Old 04-10-2009, 11:36 AM   #4
4 KRUSIN
CF Senior Member
4 KRUSIN's Avatar
Quote:
Thanks Mr Peebody. I went directly to the battery with an inline fuse. Everything is working great except the Bluetooth. I am going to start another thread on that.
Old 04-10-2009, 02:25 PM   #5
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
why not just get it from the oem harness?
pentavolvo is offline   Reply With Quote
Old 04-10-2009, 11:51 PM   #6
4 KRUSIN
CF Senior Member
4 KRUSIN's Avatar
Quote:
Initially I got it from the OEM harness. The unit wouldn't run. At first I thought it was a bad H/U, so I took it back. They bench tested it and said it was ok.. I tested the voltages again and found that the voltage from the OEM harness was 1.5 volts less than the switched voltage. I then ran a wire directly from the battery and it worked perfectly. I am at a loss as to why the OEM wire didn't work, but at this point I don't care.
Old 04-11-2009, 12:41 AM   #7
pentavolvo
CF Senior Member
pentavolvo's Avatar
gotcha hmm i wonder what happened maybe a loose fuse or something
Old 04-11-2009, 10:54 AM   #8
4 KRUSIN
CF Senior Member
4 KRUSIN's Avatar
For anyone who is interested in a similar system, I posted more details about my install on the C5 thread at the top of the page.
Old 04-11-2009, 11:09 AM   #9
sprinter1104
CF Senior Member
Send a message via Yahoo to sprinter1104
Hey Krusin,
I'm planning on doing this project in the next month or so. Thanks for posting your project in the FAQ. I'm interested in more details, any tips, tricks or particulars you'd care to share concerning the installation of the head unit?
Quote:
sprinter1104 is offline   Reply With Quote
Reload this Page Help Required - Kenwood Install - C5
Tags
c5, cigarette, corvette, install, installion, kenwood, lighter, radio, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
