Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-04-2009, 01:02 PM   #1
Stonecutter908
CF Senior Member
Stonecutter908's Avatar
Default C5: Help with switched power source
I have stumbled upon lots of suggestions on where to tap into switched power ... under the ignition, fuse panel. Unfortunately, my electrical skills are coming up a little short and I need a bit more of a how to guide.
Can someone direct me to posted instructions with pictures?
I am looking to hardwire a sirius unit. I did this in my wife's Jetta and it was simple. That was a panel under the steering column.
1) Cut the end of the cigarette adapter off the power cable.
2) Attach a ring terminal to ground and power ends.
3) Attach ring to switched power post by simply unscrewing bolt.
4) Same for ground.
I have come to realize this won't be as simple in the c5. Will I need to solder? If so, where and how?
Help please.
__________________
MODS:
Exhaust plate, visor stickers removed, Trunk partition, Z06 exhaust, CAGS defeat, Windows valet, BSM funeral, trunk lid emblem funeral, 2007 Z06 Shifter, Sumitomo HTR Z IIs, Delrin C6 knob
Stonecutter908 is offline   Reply With Quote
Old 04-04-2009, 02:45 PM   #2
slplank
CF Senior Member
Support Corvetteforum!
slplank's Avatar
Check out the C5 general and audio FAQ on top of this page and you will find all your answers. Here is a paste from one comment found there:
How do I get the acc power for my h/u?
if you look in the passenger footwell, pull out the cover and look in the top left corner. There will be a small plug with three wires (orange, yellow, & black) that are just taped up. Check out this schematic to see which fuses they use, but the yellow wire is the +12V switched, and that I am sure of.
or you can use fuse 22
slplank is offline   Reply With Quote
Old 04-04-2009, 03:19 PM   #3
Stonecutter908
CF Senior Member
I'm familiar with this info. What I need is some direction on how to make use of it. How would one go about using fuse 22 or the yellow switched wire?
I can follow directions with the best of them ... just need some assistance please.
Old 04-05-2009, 02:45 AM   #4
slplank
CF Senior Member
slplank's Avatar
I'm sorry I don't have a pic to post for you to see the wires that are available for this purpose. There is a "footwell" under the carpet mat on the passenger side. Take out the carpet mat and you will be able to pull back the carpeted cover from where your feet would go if you were sitting in the passenger seat. There are fuses, wires, etc in there.
I have read that fuse number 22 in the fuse box here is a switched source. Use your operation manual that came with the car to identify where fuse 22 is located in the fuse rack. To use it you can buy a fuse adapter from any auto parts store. You replace the fuse that was in slot 22 with one similar except it has a pigtail coming out of the fuse that you can connect a wire to.
There is also a wire harness in this area that is not being used and can offer the same switched power. I have an 04 which does not have this 3 wire harness but in earlier years it is there. I think in the upper left hand corner area of the footwell there are 3 wires in a harness not connected to anything. I believe the yelow is the 12V switched but you can test with a meter easily.
Use the search feature on the audio forum and search for "footwell" or "switched power" and you should fine some good info.
Old 04-05-2009, 06:00 AM   #5
4 KRUSIN
CF Senior Member
4 KRUSIN's Avatar
I easily found the yellow wire in the footwell as described above and used it for my switched connection. Works great.
4 KRUSIN is offline   Reply With Quote
Reload this Page C5: Help with switched power source
Tags
12v, c5, corvette, fuse, pass, poeer, power, side, source, switched
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C5 and general audio FAQ scott_fx Audio/Electronics 172 11-06-2011 10:25 AM
C5 Bose upgrade wiring notes 99HT Audio/Electronics 11 10-08-2011 05:45 PM
C5 Bose Upgrade Info 99HT Audio/Electronics 18 08-16-2004 04:02 AM
C5 Stereo Install Lessons Learned (long) (all text) MSIP Audio/Electronics 10 06-10-2004 07:29 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
