Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-28-2002, 02:13 PM   #1
Fast one
CF Senior Member
Default Installed Bose 12 CD changer and it doesn't work.
I used the three pigtail wires for power to the unit; they also feed a V1 and other circuits. The changer has power to it but no sounds out of the speakers. What did I do wrong?
Fast one is offline   Reply With Quote
Old 01-29-2002, 12:44 AM   #2
RPOZ4Z
CF Senior Member
Cruise-In VII Veteran
RPOZ4Z's Avatar
Default Re: Installed Bose 12 CD changer and it doesn't work. (Fast one)
there is also a 4 wire connector located above the BCM in the passenger footwell. if it's not there or if you have a '97 to '99 vette, check the tech tips section for instruction on installation. :cheers:
RPOZ4Z is offline   Reply With Quote
Old 01-29-2002, 06:20 PM   #3
Fast one
CF Senior Member
Default Re: Installed Bose 12 CD changer and it doesn't work. (RPOZ4Z)
The 4 wire connector was hooked up. The three wire pigtail has two connection possibilities with ground going to ground and both were tried; does anyone tap off these wires to drive other loads?
Old 01-30-2002, 11:38 AM   #4
RPOZ4Z
CF Senior Member
RPOZ4Z's Avatar
Oops, you're right.
the three wire plug has power, ground , AND data.
I believe it's the data connection that you are missing, checkout the tech tip on CD changer installation. :cheers:
Old 01-30-2002, 05:20 PM   #5
Fast one
CF Senior Member
When I checked the 3 wires with a voltmeter, one was ground, one read +12 volts battery and the third wire read +12 volts with the ignition on. Have any of you tapped off any of the three wires to drive another load such as a radar detector or are those wires only for the remote CD?
Old 01-31-2002, 01:26 AM   #6
vader1
CF Senior Member
vader1's Avatar
Send a message via AIM to vader1
You are using the wrong three point connector. The correct ones are positioned near the lower right of the fuse box. One is connected to the lower right and one is somewhat under the carpet taped to the harness with white tape.
I e-mailed the diagram that shows this to you. Hope this helps
[Modified by vader1, 10:27 PM 1/30/2002]
vader1 is offline   Reply With Quote
Old 01-31-2002, 10:53 AM   #7
Fast one
CF Senior Member
Default Re: Installed Bose 12 CD changer and it doesn't work. (vader1)
Thanks; I knew I did something wrong.
Old 04-16-2002, 02:55 PM   #8
TXSTICK
CF Senior Member
TXSTICK's Avatar
I am putting a 12 disk (stock) changer in my 2002 vert. How did you mount
the changer. I have the stock brackets but it does not look like there are any
existing holes to mount it in the storage compartment.
:confused:
TXSTICK is offline   Reply With Quote
Old 04-17-2002, 02:45 PM   #9
Fast one
CF Senior Member
Default Re: Installed Bose 12 CD changer and it doesn't work. (TXSTICK)
I drilled 4 holes and used sheet metal screws; the plastic is very brittle.
Old 04-17-2002, 06:44 PM   #10
TXSTICK
CF Senior Member
TXSTICK's Avatar
Thanks. :)
TXSTICK
2002 Vert Speedway White / Oak
ZO6 Cover / K&N Filter
Old 05-01-2002, 11:04 AM   #11
TXSTICK
CF Senior Member
TXSTICK's Avatar
Got the changer and cable installed. Works great. I drilled four holes 3/8 inch
and used rubber expansion plugs I got in the hardware section at ACE hardware. I used four 1 1/2 inch long 10/32 screws (with flat washers) to hold it in. I put it in the stock position in the well. :D :D :D
Thanks for the help! :yesnod: :cheers:
[Modified by TXSTICK, 7:05 AM 5/1/2002]
Old 07-16-2002, 01:03 AM   #12
Tuan Le
CF Senior Member
Tuan Le's Avatar
Hi guys,
I found the male connector to plug into the wire harness. But how about the other three wires, orange, green and black? Where do they connect to?
I'm think the orange wire goes to switch 12+ volt, black wire goes to ground. But what about green? :confused:
-Tuan
Tuan Le is offline   Reply With Quote
Old 07-16-2002, 02:09 PM   #13
Fast one
CF Senior Member
Default Re: Installed Bose 12 CD changer and it doesn't work. (Tuan Le)
See the "tips" section; it has to be spliced to a similar green wire on the fuse block. GM is incredibly cheap in not installing both connectors.
Old 07-16-2002, 02:15 PM   #14
Tuan Le
CF Senior Member
Tuan Le's Avatar
Do you happen to know what is the green wire being used for?
-Tuan
Old 07-16-2002, 04:02 PM   #15
Fast one
CF Senior Member
I think it's +12V when the ignition or ACC is on.
Old 07-16-2002, 04:03 PM   #16
Fast one
CF Senior Member
+12V when the Bose is on
Old 07-16-2002, 07:24 PM   #17
Tuan Le
CF Senior Member
Tuan Le's Avatar
So, if you wire this green wire together with the orange wire, would the CD changer just be on all the time?
-Tuan
Old 07-16-2002, 09:03 PM   #18
RPOZ4Z
CF Senior Member
RPOZ4Z's Avatar
Nooooooooooo!
the green wire is a DATA connection to the bose system.
READ the tech tip on CD Changer installation! :cool:
Reload this Page Installed Bose 12 CD changer and it doesn't work.
Tags
00, 12, 12cd, 1997, bose, bose12, c5, cd, changer, corvette, disk, operta, work
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
c5 coupes typically leaky? LSUgoTIGER C5 General 24 09-07-2005 11:24 PM
? about buying a C5 gmintimidator C5 General 10 03-21-2005 02:37 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
