Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-28-2002, 12:11 AM   #1
WadeGA
Junior Member
Default C5 front speaker arrangement
A number of folks on this forum have changed out the Bose system front speakers w/ another 8" sub and a 4" driver. I was getting ready to do this and made a template to use for cutting a new MDF speaker mount. In the process I noticed that only about half of the stock Twiddler is behind the speaker grille, the othe half is behind the door panel. While an 8" and a 4" will fit in the cut out, the 4" will be even more behind the door panel than the Twiddler. It seems like this will keep any speaker from sounding its best. Or, am I imagining a problem where none exists?
WadeGA is offline   Reply With Quote
Old 01-28-2002, 10:29 AM   #2
JoeyG
CF Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
JoeyG's Avatar
Default Re: C5 front speaker arrangement (WadeGA)
If your truely worried about sound imaging, two possibilities come to mind. 1. More power. 2. Fiberglass the 4 inch to hover about 20% over the cone of the midbass driver. Since bass waves are omni-directional and higher frequencies like straight waves this would compensate for the desired outcome.
JoeyG is online now   Reply With Quote
Old 01-28-2002, 09:12 PM   #3
Speed-Racer
CF Senior Member
Speed-Racer's Avatar
Default Re: C5 front speaker arrangement (JoeyG)
That's true, and I'm in that exact process.
Made the mdf cutout and still have to decide on the 4" twiddler or weather to reuse it for my set up. It's a ~3ohm speaker and may be useable. I will experiment first to see what I like the best. I'm going with 6.5" as the main then perhaps the 4" and 1" tweeter on the pillar.
Speed-Racer is offline   Reply With Quote
Reload this Page C5 front speaker arrangement
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
