01-26-2002, 10:20 AM
CF Senior Member
Re: Electrica help (Cory1970)
Definitely a ground problem. I don't know where the grounds go. You should have one from the engine block to the frame and another from the battery in back to the frame. Other than those, I don't know. Try getting it on stands and looking at where the grounds are supposed to go. If they are hanging because they are broken, you should be able to find the other end bolted down somewhere. If the bolt came out, you should be able to find the spot that looks like it was bolted on there and has wear from the bolt and ground. Lastly, try the C3 posts if you haven't already to see if someone has a shop manual for your year that can tell you what they are.
