Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-27-2009, 10:27 PM   #1
ramrodw30
CF Senior Member
ramrodw30's Avatar
Default Better C6 ACC solution
I had the ACC (on/off power) for my amp wired to the wiper fuse (non dwell) with a fuse tap and that worked OK except one annoying thing. When I turned the car off the amp turned off even though the head unit (and stock amp) would stay on as part of the delayed accessory bus (or whatever it is called) so I would lose sound. Not wanting to actually lose functionality over stock I have been trying to find a solution.
I looked at the stock amps wiring and checked a variety of circuits in the fuse box trying to find one that had the delayed function and was frustrated. Then I remembered that when I originally hooked up my radar detector to the rear view mirror I had it on a circuit that worked like I wanted the only problem was that circuit did not work with accessory on.
So here's what I did. I ran a wire from the mirror connector (pin 12 lt grn/blk) along the upper reveal molding and down along the window etc etc to the fuse box. It's very easy to do just be careful prying the molding. Then I spliced it in to my original wire so now it has power with accessory on AND has power when you turn off the motor (until you open the door).
The only potential issue I could think of was that I am powering this circuit in the mirror when accessory is on but that does not seem to be causing any problems and everything is working perfectly thus far.
And yes the bose system sucks bad. My JL Audio set up is the bomb.
Doug
ramrodw30 is offline   Reply With Quote
Old 02-27-2009, 10:39 PM   #2
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
there is a wire at the oem amp or radio u can tap that actually turns on and off with radio
pentavolvo is offline   Reply With Quote
Old 02-28-2009, 12:01 AM   #3
ramrodw30
CF Senior Member
ramrodw30's Avatar
Quote:
Well I'd like to know which one, because I could not find one that would work.
Old 02-28-2009, 12:15 AM   #4
pentavolvo
CF Senior Member
pentavolvo's Avatar
i have to pull up a diagram, it doesnt turn off till about 2 min after the radio does, and when u unlock car it will come on for a few second because the oem amp turns on so incase it needs to chime
Old 03-01-2009, 06:12 AM   #5
decappa
Junior Member
decappa's Avatar
Quote:
I'm interested in this, also.
decappa is offline   Reply With Quote
Old 03-01-2009, 11:06 AM   #6
pentavolvo
CF Senior Member
pentavolvo's Avatar
white at both the radio and amp
Old 03-01-2009, 04:43 PM   #7
decappa
Junior Member
decappa's Avatar
Thanks!
Reload this Page Better C6 ACC solution
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
