Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-25-2009, 02:38 AM   #1
Weasel 435
CF Member
Weasel 435's Avatar
Default C6 Door Speakers
A quick question...
I've installed a pair of subwoofers in the rear, which are powered by their own amp, and I've replaced the 3.5" door speakers with new ones. Now I'm to the subs in the door, and I'm wondering if it would be possible to mount my 5.25" speakers where the subs should be (after making an adapter plate, of course) on the stock wiring and just forget about the ones behind the seats.
A couple more details if it helps: 1LT, no bose, no onstar, Alpine head unit, stock amp.
Thanks.
Weasel 435 is offline   Reply With Quote
Old 02-25-2009, 08:58 AM   #2
TheKomoman
CF Senior Member
Support Corvetteforum!
TheKomoman's Avatar
TheKomoman TheKomoman
Quote:
Originally Posted by Weasel 435 View Post
A quick question...
Thanks.
Yes it's possible but you'd need to be very careful on your choice of speaker. The Delco amp is only putting out somewhere around 18-20W so you can't use a power-hungry set of component speakers. Also keep in mind there's a crossover in the stock amp that is only feeding lower frequency signals to the factory door "subs" and without knowing what that is sticking a 5.25" speaker in there may not result in much. My advice would be to leave it where you got it. If it's not giving you the results you want doing the tinkering you're proposing won't give you any better result - yanking the factory crap out and starting over again is the only way to do that. That includes the rear speakers as far as I'm concerned, don't bother.
Paranoia check - where did you get the signal to feed the subs? If you tapped off the rear speakers and used a LOC then you're not getting the frequencies you need. Get the signal from your Alpine instead.
TheKomoman is offline   Reply With Quote
Old 02-25-2009, 10:33 AM   #3
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
honestly unless u plan on adding an amp for the frts leave it as mentioned above
pentavolvo is offline   Reply With Quote
Old 02-25-2009, 05:47 PM   #4
Weasel 435
CF Member
Weasel 435's Avatar
Yeah, that's what I was wanting to know is whether there was a crossover that's only going to give low-range signals to the speakers.
The reason I'd bother with all of this is that I'm hardly getting any midrange in the car right now (with the stock delco 5.25's in the rear) and it would seem that it would be related to their placement (like if I fold the passenger seat down, I get better sound from that side).
The subs are wired directly to the head unit.
Old 02-27-2009, 10:31 PM   #5
ramrodw30
CF Senior Member
ramrodw30's Avatar
Ditch the stock amp, get a better one, get the speaker mounts from nakidparts and put component 6.5 in the door replace the 3.5 with the tweeter from the component set up and you're golden.
ramrodw30 is offline   Reply With Quote
Reload this Page C6 Door Speakers
Tags
2006, 35, adapter, c6, component, corvette, door, midrange, plate, replace, sale, speaker, speakers, subs, tweeter
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 FAQ (Frequently Asked Questions) docrings1 C6 Corvette General Discussion 216 12-01-2010 04:33 AM
C6 FAQ audio - look here first! Steve Germany Audio/Electronics 24 09-04-2008 11:05 AM
C6 PARTS & TECH NEWS 09-02-05 NEW INFORMATION CorvettePartsBob Ken's Newsletters 12 12-04-2005 01:59 PM
HERE YOU GO FOLKS THE C6 PRICING. Rick @ Les Stanford C6 Corvette General Discussion 153 07-26-2004 05:40 PM
TON's of info from the C5/C6 Birthday Bash! Jim Terry C6 Corvette General Discussion 29 05-07-2004 05:49 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
