Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-21-2009, 11:34 PM   #1
BLACK 08
CF Senior Member
Default Powered sub question ?? Please help
All I want to do is add a powered sub to give me a little more bass. My question is where do I have to hook into, the back of the head unit or do I hook up to the rear speaker to get the signal ? If I have to go into the head unit what do I hook up to ? I have an 08 with the Bose system. I am completely clueless about this stuff so please be detailed.Thanks
BLACK 08 is offline   Reply With Quote
Old 02-21-2009, 11:54 PM   #2
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
headunit or factory amp
pentavolvo is offline   Reply With Quote
Old 02-22-2009, 12:06 AM   #3
BLACK 08
CF Senior Member
Do I need to splice anything or should it have a input to hook into ?
Old 02-22-2009, 12:14 AM   #4
LTCHAPPA
CF Senior Member
LTCHAPPA's Avatar
Mine is to my Alpine HU.
LTCHAPPA is offline   Reply With Quote
Old 02-22-2009, 04:01 AM   #5
markcz
CF Senior Member
markcz's Avatar
The bass signal is not present at the wires going to the rear speakers, so stealing the signal there won't work.
You could get speaker level signal if you tapped into the bose sub wires inside the doors, or the easiest way would be to just do this
To power the sub/amp you should get the main power straight from the battery (with a fuse installed). If the sub has the 'auto turn on' feature then that's all you'd need, but that might just work if you use speaker level inputs (?). The stock radio doesn't have a 12v 'accessory power' wire that turns it ON, it listens in on the serial data line that communicates with all of the computers in the car, but it does have a 12v OUTPUT that turns on the factory amps (and stays on with RAP). You can use that signal as the trigger voltage for your new sub. I don't have my manuals with me at the moment, but you can probably find out which wire or fuse that would be with a quick search (or the C6 FAQ thread).
__________________
2007 LeMans Blue/2-Tone Gray Coupe w/MN6, 3LT, Z51, QX1, CC3, R8C Mods List
markcz is offline   Reply With Quote
Old 02-22-2009, 10:25 AM   #6
BLACK 08
CF Senior Member
Thank you very much..
Old 02-22-2009, 04:13 PM   #7
markcz
CF Senior Member
markcz's Avatar
The WHITE wire at pin B3 of the radio harness is the one you need to use as your 12v trigger to turn on your new sub, just DO NOT use it to directly power the sub. That wire is the one the OEM radio uses to power up all of the other system components, and would only be hot when the radio is on.
Reload this Page Powered sub question ?? Please help
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Audio FAQ bogus Audio/Electronics 49 01-31-2012 04:41 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
